Mixing with Toyota ATF
Old 03-30-2007, 06:50 PM
alotawatts's Avatar
My 2001 still has the factory ATF in the power steering system. No leaks etc. but I like the idea of syphoning out of the reservoir every few days and topping with new ATF.....instead of flushing, pulling lines etc. Question is would mixing say Valvoline Dexron III with Toyota ATF be bad medicine ?
Old 03-30-2007, 07:39 PM
Elkaholic's Avatar
You do that every couple days???? Wowzers. In all honestly I dont know the answer but I think it would be fine. My last truck I mixed different fluids and never had a problem.
Old 04-02-2007, 07:23 AM
GSGALLANT's Avatar
Toyota ATF is not expensive. Any reason you don't want to use it?
Old 04-02-2007, 07:37 AM
mkgarrison5's Avatar
i have a 2002 extra cab tacoma.... does it take ATF in the power steering?????
Old 04-02-2007, 09:12 AM
Elkaholic's Avatar
According to the FSM for my 04 which will have the same specs as yours then Yes. Fluid: ATF DEXRON II or III
Old 04-02-2007, 09:19 AM
rdlsz24's Avatar
I'm thinking most late model Toyotas are going to use it, since my '88 calls for Dexron II. (that was before Dexron III's time)
Rob
Old 04-02-2007, 07:51 PM
alotawatts's Avatar
- I mean every few days until I know it's flushed ......fresh pink color.
I have stayed with Toyota ATF for the transmission ....so now that I think about it .... might as well with the PS system also.
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
crashburnoveride
08-28-2015 09:20 PM
nick b
07-11-2015 04:38 AM
Quick Reply: Mixing with Toyota ATF
