Mixing Long Life and Super Long Life coolant
I've done some searching but have yet to find a definitive answer as to weather Toyota Long Life coolant (Toyota Red) is compatible with Toyota Super Long Life coolant (Toyota Pink). After reading the many threads regarding the strawberry milkshake issues with the radiator/tranny cooler, I replaced my with a Koyo (which appeared to be of very good quality and fit perfectly). I refilled the system with Long Life (toyota red), and after a day topped the reservoir with a 1/4 gal of TOYOTA PINK just assuming they were compatible. I have heard the warnings against mixing Red with Green etc. etc., but now am wondering if i need to do a flush of the system as just refill with Toyota Red or if I am good to go until my next change interval (30K miles/2 years).
Thanks all.
Thanks all.
Thanks Brian.
I have done a little more searching and found:
TSB - PG010-02 in 2002 says "The new pink coolant is 100% compatible with the current red coolant and red coolant can be used to replace, top off, or mix in with the pink coolant with no adverse effects."
here is a copy of the link. http://www.toyotapart.com/ENGINE_COO...T-PG010-02.pdf
hopefully this helps someone in the future.
Good to know, thanks for the info. I personally use regular 'ol Prestone green because I refuse to pay $25-30/gallon for any antifreeze. It better be liquid gold for that freakin price! A lot of people have told me (more like warned me) to use only Toyota fluid, but seeing as though my truck came from the factory with green (they didn't offer the Toyota coolant until about '99) and since my manual says use "any ethylene-glycol based antifreeze", I'll stick with the green. 13 years so far with out any problems!
Couldn't believe the parts guy when he said $34/gal for coolant!
I'll take semi long life so long as i don't have to flush and fill. The stuff is expensive. Prior owner had toyota red so I decided to stick with it. In the '99 Runner I had before this one, I ran the green with no problem. It sounds like the key is not to mix the red and green. I just wanted to make sure that the no-mix rule didnt apply to the red and pink. Thanks again folks for your comments and input.
Thanks Brian.
Very interesting find on your side. I might show it to my dealer to see their reaction.
The color change does not affect the maintenance procedures or
intervals established for the red coolant.
This was the same dealer that replaced my factory red with green at 30K and then replaced the green with red at 60K. (I let the dealer do the majors while in warranty; it hasn't been back since 60K). They said the green was the 'recommended' coolant when they did the 30k. I didn't bother asking why red at 60k. I'm now at 125K and sticking to red. After all, it's all I can get.
Well, I'll let you in on a little secret... I was a service manager at a dealership for 4 years. Dealer parts guys are usually idiots (although there are exceptions). A lot of them are just punk ass, zit faced kids barely out of high school. There isn't any schooling necessary for most dealership parts dept. jobs so if it's a not-so-common question, you're usually just going to get a wild ass guess rather than an honest employee admitting they have no idea. Next time find a guy that has some certs and patches on his shirt, you'll have a lot better chance getting correct info out of a tech than a parts guy or a service writer. Just my thoughts.
I look at the Toyota red coolant as cheap insurance compared to cooling system problems down the road. I changed my original Toyota red coolant in my 01 runner at 120K miles which was 4 years ago and changed it again about 6 months ago at 220K miles.
I replaced it both times when I did the timing belt and water pump. I was amazed to see the inside of the radiator, engine block and water pump where perfectly shiny with no pitting, corrosion or "gunk".
So you guys can take your chances with the cheap green stuff, but I'm sold on the Toyota red.
FOG
FOG
I still have the old radiator that was leak free and always filled with Toyota Red. I replaced it only to avoid the milkshake. Unless anyone really needs it, I can cut it open and take a look-see if the red made any difference.
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
Poncho0206
07-10-2015 06:21 PM
