Mixing ATF Fluid with Toyota
Old 07-01-2007, 03:20 PM
Hi All, I am about to do a drain/refill, and possibly a partial transmission flush(via cooler lines). I've been reading about how the toyota T IV fluid is better than typical dexron III(crisper shifts, etc), is that hold true for a 97 4runner v6 auto tranny as well? Would it be a bad idea to mix with aftermarket fluid. And if its ok to mix, which brand makes good ATF?
TIA!
Old 07-02-2007, 03:30 AM
mkgarrison5's Avatar
do NOT add T-4 to a dexIII tranny.. i was told that so many times my head spun. just get a good dexIII fluid. i run valvoline maxlife dex/merc.. but you can get the dexIII in syn with mobile, amsoil or redline.
Old 07-02-2007, 09:42 PM
wow, I must be ignorant/not reading carefully, thanks...I will just pick some good dexron III.
smthwsn357
12-04-2023 02:08 AM
09-04-2015 09:27 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Mixing ATF Fluid with Toyota
