misfires
Old 10-08-2013, 03:18 PM
FrostyBrews101's Avatar
misfires
Can a radiator resivore cap that was not on cause a misfire?
Old 10-08-2013, 04:21 PM
rworegon's Avatar
No, a loose cap will not cause a driveability issue, AFAIK.
A vacuum leak, unmetered air into the throttle body, bad plugs or wires, bad timing, etc. can.
What engine?
Old 10-08-2013, 04:31 PM
chadsy's Avatar
gotta ask... why wasn't your rad cap on?
Old 10-08-2013, 04:33 PM
Must have knocked it lose at some point idk
Old 10-08-2013, 04:34 PM
I have a whole other thread going through my list of problems cannot post link right now at work. I am sure you can find it on my profile. Quick queation can low levels of rad fluid cause misfire?
Old 10-08-2013, 04:44 PM
rworegon's Avatar
A low coolant level may give the temp sensor a wrong reading and mess with the idle, but I doubt a misfire unless it's idling really low.
Old 10-08-2013, 04:50 PM
It misfires on cold starts when the cel is lit generaly 4 days at a time then it clears and run fine
Old 10-08-2013, 04:55 PM
rworegon's Avatar
What engine?
Old 10-08-2013, 04:58 PM
What engine?
3.4l 02
shooter86314
01-07-2016 07:05 AM
Firefightersink15
11-23-2015 10:32 PM
calderp
11-16-2015 02:49 AM
the_supernerd
10-01-2015 09:20 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: misfires
