Minor rust questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-18-2003, 07:39 PM   #1 (permalink)
Send a message via AIM to Henryv
I was washing and waxing the runner today and noticed a small spot of rust I never noticed before. Its smaller than the size of a dime and is located in the small space between the rear bumper and the runner itself. I also have two thin 1" scratches near the roof above the rear door that have been there for a while and look like it has some rust in it. So if I just leave these be will anything bad happen? Or is there something I can easily do to fix it? I'm not too worried about it because they are small spots and in the area I live in there isnt any snow or salted roads but they are pretty much the only major imperfections on the rig and if possible I would like to fix it.
__________________
-1998 4runner limited 4wd-
Ugh sucks to be poor on this board
My 4runner
Henryv is offline
Old 12-18-2003, 07:59 PM   #2 (permalink)
cruizin01's Avatar
Send a message via AIM to cruizin01
If they are not in open view too much I would probably just get me some touch up paint and keep it covered. If you dont do anything to it, it will prolly get worse.
__________________
-Derek-
1998 Std. Cab Tacoma_4x4_2.7L_5 speed_PPG Gloss Black_2" RB BL_OME 882's & springs_33x12.50 MTR's on 15x10 Eagles_Westin Safari Bar_PIAA 520 SMR/Fog_Clear Lenses_Rear Diff Breather Mod_Manual Hubs_Taurus electric fan _Kenwood cd/mp3 player_Boston Z Comps_Boston Pro 10.5_fosgate 800.4_jbl 600.1_1 farad cap_bugshield_Magnaflow muff w/Borla tip_Tint 35-sides;20-back Pic Page
cruizin01 is offline
Old 12-18-2003, 08:59 PM   #3 (permalink)
cctk2's Avatar
Having Lived on the Pacific coast for 30+ years, Im well acquainted with these little cancer spots youre talking about. And thats exactly what they are. Cancer.
Theres is only one way to eliminate them I do believe. 100% of the rust itself must be removed. Not 99%, but 100%.
Now, Ive been working with various "rust neutralizing" products with some success, but I wont go so far as to say it will absolutely control this problem.
If you ignore the rust it WILL get worse. If you just paint over it, it will get worse. Its kinda become my conclusion that you can only Slow it down, UNLESS you remove it 100%. That might fall under the constraints of what we shall call "Body work".
Research is whats warranted here. Good luck.
Just a word of advise though, if you plan to hold on to yhis vehicle a long time, do something about it NOW.
cctk2 is offline
Old 12-18-2003, 09:05 PM   #4 (permalink)
cruizin01's Avatar
I wasn't trying to say that painting over it would stop all rust or make it disappear. I think we all know that the only way to stop the rust is too completely get rid of it, but like you said it takes bodywork and usually alot for just that small spot. Thats not always practical for most folks.
I had a few small dents one having a small spot of rust on it and I ended up painting the whole truck cause I knew I wouldn't be happy with anything else.
Anyway good luck
__________________
-Derek-
Old 12-19-2003, 11:52 PM   #5 (permalink)
Ok so I been searching and reading more on rust and touch up paint and will go at the larger of the two with the sandpaper, rust converter, touch up paint, langka technique. Im hoping this will work out well because it is in an area that you would have to look closely to see it so its a good test area but I still would like it to look good. However, the smaller one is like what would happen if u had a deep key scratch or if you took a knife to the truck. It is thin and I'm wondering if for that using only the rust convertor would work because I dont want to sand that part because of how thin the actual scratch is. Thanks for all the help.
__________________
My 4runner
Henryv is offline
Old 12-20-2003, 12:58 AM   #6 (permalink)
butnut's Avatar
I have a touch up biz here and for some reason, late model to new Toyotas are very rust prone to even a pencil point sized chip on the roof. This is the only place where I see rust form from such a small chip. The hole turns brown and 'spider legs' or rust veins grow under the paint from the chip...very ugly. Don't know if a diffferent steel is used or no treatment is used up there. I'm always checking for rock chips on my Runner, especially on the roof edge, found some and touched it up quick. For a scratch, here's what I'd do. Get a big needle and carefully scrape the scratch to remove loose rust. Next, get some 'metal polish' like Blue magic, Flitz, Semichrome etc, get a rag and with a toothpick, rub out the rust. You'll see the rag turn brown, keep doing this until clean. The polish has abrasive and cleaners to attack surface rust. Get some naptha or lacquer thinner and clean the scratch with the same rag/toothpick method to remove any polish. The scratch is now clean and ready to accept touch up paint and after dry, the Langka wipe. Rust is cancer as has been said, gotta catch it early or it will get worse. Good luck.
__________________
Brian
B like dat den...
2006 DuB CaB Tacoma
Speedway Blue TRD Sport
butnut is offline
Old 12-20-2003, 11:07 AM   #7 (permalink)
Quote:
That is an almost exact description of what the scratch looks like except its a thin scratch so it doesnt appear too ugly. THanks for the help, I'm going to go at the rust as soon as it stops raining for a while.
__________________
My 4runner
Henryv is offline
Old 12-20-2003, 11:31 AM   #8 (permalink)
kyle_22r's Avatar
i thought toyota learned their lesson about using cheap steel from their 1st and 2nd gen pickups...guess not
i wouldn't mind keeping my bed, but it's got cancer on the typical spots(seam above the fenderwell)...i'm either going to build a flatbed or try to find a rust free long bed box and bob it
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 12-20-2003, 04:47 PM   #9 (permalink)
rust eater.
Down here in the south at auto zone they sell a product called rust eater.Take some coarse sand paper fold it up and sand the rust outl if you can. Spread the stuff on it and about two or three hours it converts it into primer.Then touch up with paint.Looks better than a rusted hole.The junk works .I have tried myself.A year later still no rust. It dosent hurt the surounding paint either.
rugerm44 is offline
Old 12-20-2003, 04:53 PM   #10 (permalink)
kyle_22r's Avatar
if i want to save my bed, i'm going to have to cut the rust out and weld a new piece of sheetmetal to it, as the rust has eaten all the way through. i have a good sized dent in the side behind the cab though, so i might have to just end up building a flat bed
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 12-20-2003, 08:34 PM   #11 (permalink)
f had rust spots on my old truck that needed work but I knew I was not going to get to them for a while. I took a sharp chisel and scraped off the rust (these were spots at least as big as a quarter). Then I smeared bees wax on them to keep them sealed up. My truck didn't look any worse than it did with the rusty blisters and it did help to keep the rust from eating holes through the metal. I cleaned it up good the following summer and had the truck painted. The spots did not come back so I guess I helped it.
__________________
1995 4Runner SR5 V6 3.0 5 spd
oldsub86 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Discovered rust / Repair questions jht3 86-95 Trucks & 4Runners 14 07-26-2007 05:25 AM
Minor, Minor Teardown CoedNaked General Vehicle Related Topics (Non Year Related) 0 10-03-2006 10:19 PM
About to start repairing rust on my 95. Have a few questions. ThomasJ 86-95 Trucks & 4Runners 16 08-18-2006 06:04 PM
Questions about using rust converter... Ontario 95.5-2004 Tacomas & 96-2002 4Runners 16 03-21-2006 12:18 PM
Frame Rust Questions CTB Early Land Cruisers 6 09-07-2003 09:58 AM
2009 InternetBrands, Inc.
