Minimum thickness for front rotors
Old 06-24-2007, 05:39 PM
GhostriderTx's Avatar
Does anyone know the minimum thickness in order to turn front rotors on a 2001 4wd with 16 inch rims. I am debating new rotors but need to order them in advance. However I got 70k on the original set so I may not have much wear and might be able to continue to use the tactory rotors if I get them turned.
Old 06-24-2007, 06:10 PM
Bigblock's Avatar
If you have to ask -replace them!Dont be a fool.
Old 06-24-2007, 07:05 PM
GSGALLANT's Avatar
Here's some info for you.
Rotor Standard Thickness (New): 0.866"
Rotor Minimum Thickness: 0.787"
There is no set minimum thickness required to turn them... it depends how badly they are warped. Typically, the guy would remove 0.010" (maybe 0.015") per side, so a total of 0.020"-0.030" off your total thickness. I like to see a thickness of at least 0.830" before I get them turned if they are really bad.
Colington
03-08-2020 09:51 AM
montanatruck
02-26-2017 07:07 AM
88sasturbotoy
08-11-2015 01:56 AM
KyleT
07-21-2015 07:54 PM
msane99
07-11-2015 08:08 PM
Quick Reply: Minimum thickness for front rotors
