mid-pwer cam for the 3.0?
Old 05-07-2003, 02:39 PM
aviator's Avatar
Hey guys! I knoe there is a mid-power cam for the 22r/22re series engines. i would like to know if there is a similar product available for the 3.0. the 3.0 is an SOHC design so there should be one by now.Any tips would be appreciated thanks Aviator
Old 05-10-2003, 01:23 AM
shamrockmac5's Avatar
doaracingengines.com has what your looking for @ $275 per pair but my gut tells me why spend a ton of money on upgrades to a 12 valve motor? I'll be looking to do performance mods to a swapped in 3.4L 24V quad cam. More cubes w/ more valves = loads more performance.
Old 05-10-2003, 10:23 AM
Churnd's Avatar
Plus, if you do the DOA cam upgrade, you'll have to upgrade the heads too. All that would cost around 2 grand and yield at best 30 hp. Not worth it.
Old 05-10-2003, 10:28 AM
Vato Loco's Avatar
With that money on a 3.4 V6, you can get the Supercharger and also get more than double the HP
Old 05-10-2003, 11:07 AM
The owner @ DOA qoted me around $1200 I think for the reworked heads w/ cams. that's when I did the math and decided to wait till after I do the swap. I would like to see about a supercharger down the road a while after that. I don't think there are all that many 2nd gen's w/ a blown 3.4L so it will hopefully be a bit of a rarity. I could probably get a 3rd gen runner for about the same money but I have always loved the 2nd gen body style more even though the differences are slight it matters to me.
Old 05-10-2003, 11:16 AM
aviator's Avatar
I have'nt checked the DOA site yet so this might be a silly question later but why would the heads have to be changed? the upgrade to the 22r/re cam does'nt need a new head...ant thoughts? Aviator
Old 05-10-2003, 11:25 AM
they recommend bigger valves w/ a different grind angle as I recall
Scatpac
05-25-2017 06:47 AM
tobylab
01-18-2016 07:06 PM
nonstop
7
08-11-2015 09:26 AM
Fakayayou
08-09-2015 12:47 AM
tobylab
07-12-2015 12:53 PM
Quick Reply: mid-pwer cam for the 3.0?
