Are metal tabs necessary?
I would like to mount some lights on a section of metal tube that doesn't have any tabs welded on to it. Should I just go and find someone who will do that or are there any suggestions that are almost as stable and solid?
I kind of have the feeling that there really isn't but I figured I'd try anyway
Mounts
You could also use the ARB tube mounts that many folks use to mount their CB to the ARB before they started putting the tabs on the ARB.
http://www.4by4connection.com/cbaccessories.html
Good luck!
Good luck!
How big is the tubing?
If around the size of a Yakima cross bar, you can use the Yakima Snap Arounds.
The hole for the bolt and plastic wingnut you can use for the light stud instead.
I test fitted a Hella 500 on my cross bar years ago before getting the Yakima Load Warrior light mount plates instead.
George:
Do you have any close-ups or pics of those straps by themselves?
Brian:
How have those been holding up? That looks like a little friendlier solution.
Corey:
The width is about grille guard size, I dunno - 1.5"? That looks like it would be good but you have to slide it on via an open length, right?
Thanks guys, keep the suggestions coming, I appreciate it!
Brian:
Corey:
Originally Posted by Tacoma Dude
Brian:
I think both Corey and midiwall (Mark) use these for their CB antennas, so you might ask around for some other input, but I think they'd work fine from what I've seen of them.
Corey:
They open up so they can fit a Yakima round bar or a Thule square bar.
Open up, snap or slide on over the tubing.
gibbonsballer10
10-26-2023 07:13 AM
ashamsuddin
17
01-13-2023 03:17 AM
Dale Johnston
11
10-31-2015 10:22 PM
sonorn67
09-19-2015 05:39 PM
