Mechanical Oil Pressure Gauge
Old 07-12-2004, 02:28 PM
Ritchie's Avatar
I have an '03 Tacoma Prerunner with the 2.7 motor. I would like to install a mechanical oil pressure gauge that is not a factory item. Have any of you out there done this?
If so, what part/brand did you use, and where did you run the oil line connection on the motor?
Any help is greatly appreciated!
Old 07-12-2004, 03:06 PM
3.4v6's Avatar
ive done this to my v6 motor. i dont know if it will be the same but near you oil filter there should be at least 2 extra ports with plugs in them. i used the autometer oil gauge and that comes with everything that you need. in my case the fitting was too small so i went to home depot and bought another fitting the next size bigger. just run the cappillary line from the fittings to the guage and your set.
if i had to do it all over i would use an electrical gauge since i dont want any fluids running into my cab
Old 07-12-2004, 08:22 PM
Ritchie's Avatar
Hey, thanks for the reply. I have seen the spot you mentioned, but did not know that is was an option.
Where did you put your gauge and how big of one did you buy? I would like to install mine just to the right of the ECT power button on the flat area of the dash.
Thanks again.
Old 07-12-2004, 09:25 PM
jimbo74's Avatar
i have a sensor now that is hooked up to something... its my oil pressure light for the dash, however, since the engine swap, i have never seen it on.. the dash light comes on occasionally at startup... but even if i disconnect it nothing happens... can i just disconect it and run an aftermarket guage? at least something i know is working.....
Old 07-13-2004, 04:53 AM
Ritchie's Avatar
I am not sure that an electrical oil gauge would work off of that sensor wire. Think of it this way, if your light comes on intermittently, your gauge might do the same thing?
I have had bad luck with electrical oil gauges in the past, so I will install the mechanical style to be sure all is well.
Old 07-13-2004, 08:14 AM
3.4v6's Avatar
Thanks again.
i got an autometer oil pressure gauge , size 2 1/16. i custom molded triple gauge pod from a ford zx-2 to fit my a-pillar.
i know you can get the pods at www.gaugepods.com
http://www.gaugepods.com/toyota.html
Old 07-14-2004, 05:23 AM
Ritchie's Avatar
Right on 3.4v6. I appreciate the sharing of experience and knowledge.
Thanks.
Old 07-14-2004, 09:54 PM
jimbo74's Avatar
i saw an apc oil pressure guage at kragens... im not really into apc products, however i was looking at it, and it has its own sender unit... if the threads match, could i remove my current sensor and just put it in there? and mount a guage in a pod on my pillar?
Old 07-14-2004, 10:53 PM
superjoe83's Avatar
i would then probably need to know what pressure my truck should be at... its a 22r and the port for the sensor is either jsut above or below the oil filter.. cant remeber off hand
the stock place for an oil pressure tap is under the oil filter by the pan, my 22r has about 10-15 psi when idling hot at about 700-800 rpm., fast cold idle is about 60-70psi, i am running 10w-40 oil
Old 07-16-2004, 07:59 PM
jimbo74's Avatar
so pluging in a sensor to this port is fine?
Old 07-17-2004, 06:28 PM
jimbo74's Avatar
to the top
Old 07-18-2004, 01:50 PM
superjoe83's Avatar
so plugging in a sensor to this port is fine?
yes its fine, Toyota uses that port for the factory oil pressure sending unit in my '84
Old 07-18-2004, 05:22 PM
jimbo74's Avatar
thats currently where my sending unit is too, and its hooked up... but the light never is on except with acc on and not started..... when i start it, it is never on, even if i disconnect the sensor..... so i dont think it matters and would rather have a real guage anywyas... might eliminate my whole dash.... the only things on it are fuel, and temp that i use anyways.. but i wnat to install a real temp guage as well.. the speedo doesnt work, nor the odo, and im putting in a gps so i will know my speed....
bigjstang
08-25-2021 12:41 AM
Jdgarrison
10-01-2015 05:22 PM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Mechanical Oil Pressure Gauge
