Maybe somthing wrong with VSC????
ok so when i got off work today i put it in 4wd unlocked to drive for 10 miles a month like ur suppose to do..
sooooo whenever i came to a stop at a light or stop sign and pressed on the gas to get going the vsc light would go on.This happen to me at least 6 times driving home..the conditions were dry..one time i was turning onto a busy street and when i pressed on the gas the car barley moved i pressed down really hard on the gas and it took about 5 seconds to get the car moving. i hope nothing seriouse is wrong with the 4wd.
anyone ever had this happen to them?/ or have any ideas why this would happen???
teh answer is yes
oh there are 120 specific conditions that can cause this. where to start, eh ?
teh problem is likely nothing at all wrong with the drivetrain. vsc will crap out
if any other ecu controlled system is out of spec.
so your best bet is a full computer diag from a dealer. it will save trouble
in the long run to get it done.
teh answer is yes
Funny, you asked this very question exactly one year ago on another 4Runner Forum! Were the answers not sufficent then?
http://www.toyota-4runner.org/showth...threadid=30302
Anyway, I said it then and I'll say it again:
WHAT YOU ARE EXPERIENCING IS THE NATURE OF VSC. YOUR 4RUNNER IS FINE.
This is the main complaint most, if not all owners have w/ their vsc equipped 4Runners. The computer senses the slightest bit of wheel spin (even though you may not feel any at all) and it tries to compensate by slowing the entire vehicle down. Since you're accelerating from a dead stop, the system slows you down to a crawl.
If you want to keep this from happening in the future while driving around town in 4HI, do the Andy Mod. It disables trac & vsc with the flip of a switch.
Oh oh my favorite is the O2 sensor. WTF you might say? But yes my friend the O2 sensor will set the VSC light off as well as the CEL (check engine light).
Can you check it? well typically not unless the CEL has lit up. If that IS the case take you truck to local auto parts rent the OB2 scanner and see what the code is. If this IS NOT the case pop the hood disconnect your NEG (-) battery terminal for 2 minutes then reconnect drive around and see if it happens again.
Aaron
Aaron
If you want to keep this from happening in the future while driving around town in 4HI, do the Andy Mod. It disables trac & vsc with the flip of a switch.[/QUOTE]
Cough Cough and the ABS (my least favorite side effect).
Aaron
Aaron
Andreas (The Andy in AndyMod)
Aaron
zytra
01-24-2019 03:16 PM
primordialbeast117
12-19-2015 12:23 PM
charlie_fong
09-27-2015 10:06 PM
