Master Control Switch Doesn't Work for Pass. Window BUT Pass Window Switch Works
Old 05-18-2009, 08:57 AM
prhime's Avatar
(as mentioned before. i was given this truck after my dad got an 06 4runner)
-The passenger window switch controls the window up and down with no problems. The window can't be controlled by the driver side master control unit.
-the passenger swtich on the MCU feels different (tried to get the best description and all i could come up with was - lighter and sfoter).
-i've pulled out the switch unit (wiring allows it with ease). and tried to tack of the panel to clean/inspect but in the process broke 1 tab. so i figured i'd see what the board has on thoughts before i go back in this weekend.
I have found these two threads:
https://www.yotatech.com/forums/f2/p...problem-61768/
https://www.yotatech.com/forums/f2/p...-wiring-40255/
*96 4runner limited
Old 05-18-2009, 09:01 AM
Staff
DeathCougar's Avatar
Sounds like the pass control switch in the MCU is bad to me. Very easy fix, however, depending on the year, some of those switches only fit certain years.
It spreads like this:
1. 96-97 only
2. 98 ONLY
3. 99-02 only
depending on your year, they used any one of those.
Old 05-18-2009, 09:03 AM
prhime's Avatar
got it. I have a 96 so will do some looking.
easy in the sense of pop out MCU, unscrew and remove back (try not to break tabs this time), swap switch and reverse?
Old 05-18-2009, 09:08 AM
Staff
Yea, it really is that easy. Pop the cover off from the front, switch the panels, and viola! Its that easy. Since you have a 96, you will need a switch from a 96 or 97. They used a wider lock button and a different wiring configuration those years.
Old 05-19-2009, 05:37 AM
prhime's Avatar
time to go hunting for one.
thanks. i'll let you know how it went
Old 05-19-2009, 12:52 PM
prhime's Avatar
So far I have found this:
http://cgi.ebay.com/ebaymotors/1996-...QQcmdZViewItem
and other prices for a switch are in the $50+ range online. I haven't had a chance to hit the local yards in Brooklyn to find one but I am thinking that if I see a switch for $50 and a full MCU for around the same price on EBAY:
A) option 1
B) option 2
C) Option 3
D) Option 4
E) Switch Doctor
Old 05-19-2009, 03:36 PM
Staff
That switch from the 1st Ebay ad is NOT the master window switch. That is just a pass side switch, and the guy doesn't even have the interchange correct.
The one listed as "Option "A" is the switch you want
Old 05-19-2009, 06:44 PM
prhime's Avatar
i figured as much esp. after your last post saying i needed a specific year.
part en route also have the center console coming in (thanks to iceman) hopefully get both this week.
warrenjcarlson
07-22-2016 11:47 AM
Beavah
9
11-12-2013 07:31 PM
Yoda
7
06-22-2002 07:14 AM
Quick Reply: Master Control Switch Doesn't Work for Pass. Window BUT Pass Window Switch Works
