Manual Xmission Noise -- '96 4Runner 3.4L V6 4WD - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-20-2009, 10:44 AM   #1 (permalink)
Last night I began noticing a "swishing" noise in 3rd and 4th gears. It goes away in neutral. When I wiggle the shift lever, particularly in 4th gear, I can hear the volume of ths noise change with the wiggles. Started out barely audible and now I can hear it over the radio.
I'm assuming this is likely internal bearings wearing out. Would you folks recommend, say, a Lucas product, to mix in with the oil? Which, by the way, I changed about 3 years ago. Vehicle has 270K miles on it.
Thanks for any help!!
pizzabob is offline
Old 11-20-2009, 10:49 AM   #2 (permalink)
cpizzle42's Avatar
maybe a throw out bearing? Does pushing the clutch in effect the noise?
__________________
1996 Runner limited, V6 4wd, 5sp 5.29 gears
Suspension-Sway-a-way 2.5 coilovers and camburg uniball uppers,Sonoran steel 1.2 REAR kit,*NO SWAY BARS*
Tires and wows-35x12.50 BFG KM2's on 15x8 black steels, cut fenders and cut back firewall.
Misc-lock right in the rear, Cobra Cb, Viair On board air, Bud Bulit Skids, 55 watt rock lights, K&N intake, flowmaster exhaust. Power Steering Cooler
Its not cool being cheap, and its not cheap being cool!
cpizzle42 is offline
Old 11-20-2009, 02:12 PM   #3 (permalink)
Quote:
Hi, C Pizzle, thanks for reply -- No, it has to be in the xmission since wiggling the shift lever changes the noise level. And clutch engagement/disengagement does not affect it.
A change since my last post -- I can now hear the swishy noise even when coasting in neutral, as well. And it always ceases when I stop rolling. Would that tend to indicate a bearing leading to the drive shaft, since it seems to be related to road speed?
One local transmission shop I just visited quoted a bearing kit at $578. Hello -- I think I would go find a used tranny before I paid that much for the stupid kit, no??
pizzabob is offline
Old 11-20-2009, 03:08 PM   #4 (permalink)
yes I would likely go for a barely used tranny if you can find it.
cpizzle you are a Limited with a 5 speed? I thought all Limiteds were automatics?
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Fact. Rr. Locker/Diff Breather Ext.
Old Man Emu lift springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders-prevent body damage!
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts/Bushwacker Extend a Fenders
all my photos are over on Facebook now-I gave up on photo hosting sorry....
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 11-20-2009, 05:08 PM   #5 (permalink)
3w41d's Avatar
Send a message via AIM to 3w41d
try replacing the shifter seat bushing in the shift lever. i had a whine in 5th gear that went away after i replaced it. they're only like $20 to replace both the shift seat and the socket. so if it doesn't help, not out alot of money and it might save you a transmission rebuild.
here a writeup and more info(done on a 90's pickup but they're all the same)
http://www.brian894x4.com/Shifter.html
here are Marlins replacement bushings
http://www.marlincrawler.com/transmi...-shifter-seats
white one
http://www.marlincrawler.com/transmi...shifter-socket
$6 one
__________________
2000 Toyota 4Runner. 232,000 miles 6Q7 3RZ 5spd 4WD
TJM T-17, BFG 31x10.5 A/T's, Black steelies, Bilsteins, Drilled/slotted rotors, Flowmaster 40, ISR mod, 6000k HID's, Red LED gauges, SR5 Sport bucket seats, Black Widow safari rack, Pioneer head unit, Xplod amp and 12" sub
3w41d is offline
Old 11-20-2009, 07:38 PM   #6 (permalink)
Nuthuts96's Avatar
Location: Burlington, VT previous: Everett, WA; Bellingham, WA
Quote:
x2. i thought the 5sp was only offered in the SR5/base trim level (with 4x4 offered in all packages)
sounds like those shifter seats may help, pizza- in fact, i'm bookmarking that now as one of my future projects.
__________________
Scott
1996 White 4Runner-4x4-SR5-5 speed-gold trim
140k-265/75/16 Yokohama Geolander AT/S
Cupholder Mod- Overhead Console Mod
Nuthuts96 is offline
Old 11-20-2009, 10:59 PM   #7 (permalink)
cpizzle42's Avatar
Maybe you guys are right? I could swear mine says limited on the back of it?? Haha I am embarrassed I dont know....
__________________
Old 11-20-2009, 11:00 PM   #8 (permalink)
$6 one
[snip]
Thank you, 3w4Id -- I'm going to give it a try. I just replaced the oil and laced it with 50% Lucas treatment, with absolutely no change in the noise... I would've thought that the thicker oil would make some small difference. Since the shift lever seems to modulate the amplitude of the noise, what you posted makes a lot of sense.
Couldn't hurt to give it a try!!
Gotta go to bed... getting late... full as a tick... We had pizza tonight for dinner, as usual...
pizzabob is offline
Tags
1996, 4runner, 56, 85, bearing, clutch, drive, driving, makes, manual, miles, noise, problem, release, swishing, toyota, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
