Manual hub question
Old 08-07-2003, 10:30 PM
jimrockford's Avatar
Question Manual hub question
Do the front axles rotate at all in 2wd with manual hubs in the "free" position? I've got a split in one of my CV joints that I haven't had time to replace. Am I doing any damage to the joint, assuming it's not already shot?
I'm wondering if there's enough friction with the wheel turning to make the axle turn.
Old 08-07-2003, 10:44 PM
its2slo's Avatar
no they dont turn because you are free wheeling. no youre not hurting anything, but eventually they could fail so it is a good idea to do it sometime....but you know that.
Old 08-08-2003, 04:24 AM
gwhayduke's Avatar
Since you have manual hubs, ITS2SLO is correct. Once you engage the hubs the axles will spin.
Old 08-08-2003, 06:29 AM
Victor's Avatar
Pound out the studs on your axle side when you pull the CV. Makes a ton of difference getting them in and out. I only have to jack under the bottom A-arm about 1/2" inch to do mine - no disassembling the upper arm or ball joints.
I replaced my studs with the same size bolts. Total investment was $12 for both sides.
Old 08-08-2003, 07:27 AM
Glenn's Avatar
No the axles shouldn't move with the hubs in the FREE position. To check to see if they are, you can pull the transfer case lever >slowly< toward 4HI while moving. If the gears start to gnash, don't continue into 4HI. That means the front driveline is not engaged.
glowz825
01-25-2022 09:28 AM
oldirtydirt
02-23-2020 09:30 AM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Manual hub question
