Manual Hub Bolts
Manual Hub Bolts
Do you need ones specificaly made for them to mount them, or will the ones from the ADD hubs work?
thanks,
-Bryan
thanks,
-Bryan
Not exactly sure what you are talking about but....it should be a straight swap with no new bolts needed. You could get some shiny new screws for the Aisin hub dial to attach to the hub body. Check out Metal22ica's write-up in the Tech section for more info. Good luck!
Scott
Scott
kgcwb44
01-29-2023 10:02 AM
TransAmBandit
07-28-2015 11:30 PM
Steven.m.paulk
07-24-2015 01:44 PM
