| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Making the Switch! Questions...
__________________
'99 Tacoma 5spd 2.7 4WD Xtra cab TRD K&N Intake, headers, Hella's, Magnaflow cat, cat-back w/ Magnaflow exhaust, gray wire, fosgate(s), Kenwood deck. Hopefully more to come. '05 Banshee scream 5th element rear, setup for 7/7-->'06 custom welded steel DJ/trials frame. Line-X frame coat. Avid BB7 mech. My first frame job. holding strong |
#2 (permalink) |
There is too a highway thats over 55 here
![]() ![]() The George Parks hwy is 65........only advisable to drive that fast in the summer though
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#3 (permalink) |
Ha yeah you're right.
When I grew up there it was all 55...i guess it's been a few years since I've lived there though. And I was in Homer.
__________________
#4 (permalink) |
Anyone?
__________________
#5 (permalink) |
U joints, leafs flat? air filter oil or not just to see what the individual before was thinking. ask for maintenance records and type of oil used. And look for any modifications!! is there a towing package? check the gear oil this is a gimme!! suspension other than leafs if the leafs are flat then you know they were putting weight in the bed bump stops on front if they are clean then coil overs are likely to need replaced!
I would go in to this with the thought that I am replacing the suspension any how. stock is not so good my only real gripe with them. on the frame just inspect and see if it is rusting and if so call toyota and see if it has been checked if not and the frame is bad and the price is right buy it and take to toyota for the money!! Quick buck!! not every body knows about the recall!! then you have more to spend on another. Basically the frame and suspension and ujoints amount of lift are the things that a mechanic should look for other than what he should already know to look for!!
__________________
Flyin High 4:19 and Green!!! '99 3.4L 4x4 All Manual Taco 2.5" lift OME CO and Alcan Leafs Deck Plate Mod. |
#6 (permalink) |
yeah I told him all of those things just looking for anything engine specific...or problems these years had. I think I got a good amount covered just looking for anything I bypassed....
__________________
