maintained OD switch on 3rd Gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-14-2008, 04:02 PM   #1 (permalink)
anniesball's Avatar
Is there a way to have the selection between OD on or off maintained between the vehicle being turned off. I don't drive on the freeway much so I'm typically not using OD. I find myself pressing the button everytime I get into the vehicle. In addition I'm reminding people who use the truck to press the button also.
Thanks
anniesball is offline
Old 11-14-2008, 04:26 PM   #2 (permalink)
Jay204's Avatar
nope....pretty sure it reset's its self when the ignition goes off.
__________________
2000 4Runner SR5 4x4 197k CONVERTED to LIMITED
30000K HID Phillips
Powder Coated Rims
BFG A/T KO
rear-diff lock
4:30
Volant CAI
Xenon Sport Flares
JVC KW-AVX810 DVD
1x12inch Alpine-R 1500w
CY-PA2003U 1200w
SS 1.2 coming SOON!
Jay204 is offline
Old 11-14-2008, 04:39 PM   #3 (permalink)
KZN185W's Avatar
there's really no need keep the OD switch in the off position. even while ON, the tranny will only shift to OD when the speed of 80 kilometers per hour (50 miles per hour) is reached and at around 1800 rpm (in my case).
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 11-14-2008, 04:44 PM   #4 (permalink)
unitofstuff's Avatar
Mine is an in or out button, so I'd assume mine maintains the setting. Did they change the button in certain years?
unitofstuff is offline
Old 11-14-2008, 04:47 PM   #5 (permalink)
98runner210's Avatar
yeah mine is an in and out switch. I find no need to mess with it unless I am towing or driving through the hill country at low speeds. Working in the shop I find some transmission failures from people messing with it all the time when they don't need to. It really wasn't designed for just high speed use or to be cruising in 3rd all the time. It is computer controlled so there is really no need to try and outsmart it.
__________________
'98 4Runner Limited White w/ silver flares
98runner210 is offline
Old 11-14-2008, 04:47 PM   #6 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Mine had the same thing. If you pushed it in, it stayed in. Same way on my corolla.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is online now
Old 11-17-2008, 03:43 PM   #7 (permalink)
anniesball's Avatar
Well I should have said I have an '02 4Runner. The OD switch is not maintained, it is momentary.
I live in very hilly territory in norther california. If I leave it in OD it will be shifting all the time. I am under the understanding that shifting from 4rth to 3rd over and over will decrease the life of the transmission. Therefore I leave it in 3rd as I'm not on the freeway very often.
Old 11-18-2008, 04:39 AM   #8 (permalink)
GSGALLANT's Avatar
Try leaving OD on and hitting the ECT button instead to drive around the hilly areas. It allows you to maintain higher rpm's before the tranny shifts, so it may cause less up/down shifting for you in the hills, depending on how steep they are and your driving style, of course...
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 11-18-2008, 05:05 AM   #9 (permalink)
mt_goat's Avatar
I think I saw on here where one guy changed the switch to one of the older style that isn't momentary. I think it was in the 3.4 swap section.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
WTB: 3rd gen 4runner Limited wood grain Door switch bezels wizzells The Classifieds GraveYard 0 04-12-2008 07:54 PM
FS: 1994 4Runner - Clean, Very Nice, Well Maintained MRunner The Classifieds GraveYard 1 12-21-2006 10:04 PM
3rd gen 4Runner Fog Lamp Switch - Part number? KZN185W 95.5-2004 Tacomas & 96-2002 4Runners 6 03-13-2006 03:07 PM
In-Cab Winch Control in a 3rd Gen Toyota 4Runner Using an OEM Power Mirror Switch Robinhood150 Off Road Enhancements 0 01-02-2006 06:43 PM
Power sunroof switch 3rd gen to 2nd gen Mod?? Mossback74 95.5-2004 Tacomas & 96-2002 4Runners 6 04-24-2004 08:57 PM
2009 InternetBrands, Inc.
