MAFF cleaning on 2002 3.4 v6 tacoma
Old 02-19-2007, 11:59 AM
mkgarrison5's Avatar
hey guys is there a link on how to remove and clean the maff sensor? also, any tips on what or what not to do?? the electronics cleaner you get to do this, is it compressed air or actually a chemical?? thanks guys
-- bc i changed plugs, fuel filter, greases shafts, changed front, rear and t-case gear oil, air filter is clean and etc oh and seafoamed one can in the intake and 2 in the gas tank andyes i had the negative batt cable pulled and still the same gas mileage!.. it runs a lil smoother but thats it.. 80k miles on the truck
- side note, it had original plugs and were shot to shiiit. white center and and darker on the outside edges
mike
Old 02-19-2007, 12:21 PM
Gideon's Test's Avatar
Disconnect the MAF electrical connector, spray it liberally. Let it dry thoroughly (5 minutes), reinstall...It is a chemical, under normal aerosol pressure...
Old 02-19-2007, 12:23 PM
do you clean the exposed part of the sensor or all of it? never took one out... also its just 2 screws and a clip right?
thanks for the replies btw
Old 02-19-2007, 12:41 PM
It won't hurt anything, but really all you need to spray is the heated wire...
Old 02-19-2007, 03:11 PM
MTL_4runner's Avatar
Just the part that sticks into the air intake tube (pay special attention to the sensor wires!!!).
MAF cleaning writeup:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Old 02-19-2007, 04:39 PM
CLEANSR5's Avatar
Yea I actually just cleaned mine today, thanks to the help of 4x4wire. My 3rd Gen Runner was stalling like mad, so I decided to clean the MAF. It worked wonders, I'm not idling around 600, it's nice. But yes, as stated above you need to get those 2 little pins, that will do it.
Old 02-20-2007, 04:10 AM
thanks guys!
Tacoma1313
09-08-2015 01:27 PM
Dparr2ndgen
09-08-2015 01:06 PM
94whiterunner
07-12-2015 07:15 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: MAFF cleaning on 2002 3.4 v6 tacoma
