| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Lug Nut Torque?
#2 (permalink) |
just torque the crap out of it... that usually works for me
__________________
1998 5spd V6 4Runner SR5 OME 881/890 4Crawler diff drop Tokico trekkmasters WabFab quick disconnects LC wheels Goodyear Wrangler Silent Armor ATs (285/75/16) |
#3 (permalink) |
But that can also warp stuff and cause the lugs to seize.
The proper tourqe is about 92ft/lb.
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#4 (permalink) |
Rock...the torque value you want is 83 ft/lbs. I got it from here or look at page SA-34 in your FSM.
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#5 (permalink) |
Thanks for the replies everyone. I didn't want to over torque as i know that can cause warping.
But unfortunately all is for not. Auto parts warehouse sent me the wrong brembo rotors. 5 holes for studs as opposed to the 6 on my truck. The rotors are significantly smaller also. I checked their website again and it lists two brembo rotors as fitting my truck. I ordered the slightly less expensive ones....i'm wondering if they are for a 2wd instead of 4wd. Their website doesn't specify. Does anyone know the correct part number for brembo rotors for a 2004 toyota tacoma 4wd with 3.4L? On the upside i spoke to customer service and they are going to pay to ship them back. He checked the website and sure enough it said that the part they shipped would fit my truck......? Oh well back to my warped damned rotors for another week or so.... RC |
#6 (permalink) |
anywhere in-between 80-90ish you will be just fine.
__________________
-Eric 2002 SR5 4WD Goodyear Wrangler Duratrac 265/75/16C Deck plate + ISR OME 881/890 Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims |
#7 (permalink) |
Old wives tale. I probably have gone through more sets of wheels and tires than most anyone on this forum (for the cars I've had) and I've always just torqued those badboys down as much as I could without extending the lug wrench. I have NEVER had a problem (on track cars or otherwise), and even have a hard time imagining exactly how a man could apply torque to the level that could cause warping (assuming the wheels are hubcentric). I take my time with plenty of stuff, but the day I take a torque wrench to my wheels is the day I go to the therapist and get some meds for OCD.
I'm half kidding here, it just doesn't seem like a big deal to me as long as you torque them enough. But to each his own, why you are at it, you better torque your license plate to spec!
__________________
#8 (permalink) | |
Quote:
So i can safely say that i was warping the rotors. since then i use a tourqe wrench whenever i have it nearby, the rest of the time i know about how much force it is and go to that. But the biggest reason i tourqe them is that once back when i used to just tighten them as hard as i could. My mom was driving the car once and got a flat. no matter what she did could not get the lugs off. Eventually we found out about it (this is after here being stuck there for over an hour). Even when i got there i could not get them off, i had to use a big cheater bar to get them off. The wheel had been on the car for a long time and they had seized. Since then i always tourqe them to make sure that the lugs can be removed on the side of the road by a lady should it need to be.
__________________
#9 (permalink) |
fair enough, torque away
__________________
#10 (permalink) |
In any case i check/re-torque mine after 25-40 miles.
__________________
"Can't be scared of that skinny pedal." |
#11 (permalink) |
I just tighten them down...never had a problem either.
__________________
1991 Pickup - STD Cab - 22re - 5spd - 2wd - DD - Cobra CB w/4ft whip - Hella 500ff - 27" swampers - Flowmaster 40 series - Aussie locker |
#12 (permalink) |
I agree, 80-90 has always worked for me...just remember to torque the lug at 12 then 6 then 9 then 3 and so on... in order to torque evenly
#13 (permalink) |
all nuts on a single wheel should match in torque. for hot and cold and also hitting obstacles, the wheel is under the best load distribution when set correctly
that is why a torque wrench is important |
#14 (permalink) |
The main reason why torque is important for the lugs is because if you over torque them the studs will stretch and weaken over time...breaking off...seen it happen....
you usually see this with the people that use impacts to tighten them down
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#15 (permalink) |
Here is a handy website for wheel torque http://www.discounttiredirect.com/di...heelTorque.jsp
__________________
My Winter Beater 1999 4Runner SR5 Sold my 4Runner. Bought a 04 Tundra. Stuff I have done: Tokico Trekmasters (Stock Suspension) Kenwood Stereo. True Flow Airfilter Big ole Stock Tires Firestone Destination A/T 01 Tundra Brake upgrade 10/02/08 Best mod ever. |
| Tags |
| 2008, 2wd, 4runner, 94, laws, lug, nut, nuts, pickup, rotors, tacoma, threaded, torque, toyota, wheel |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3rd Gen 4R wheel lug nut torque specs | ohio4runner4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-23-2006 10:38 AM |
| Lug Nut ?'s | brendonv | General Vehicle Related Topics (Non Year Related) | 3 | 05-15-2006 01:35 PM |
| Lug nut question | xSLICKx | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-16-2005 09:48 PM |
| lug nut qusetions | rockfordrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-31-2003 05:55 AM |
| stripped lug nut??? | metal22lica | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-10-2003 02:56 PM |
