Ltd Rocker Panel retrofit onto a SR5?
I searched and didnt find anything about this..
I found a some limited rocker panels on craigslist and I was thinking about herculining and putting them on my SR5, does anyone have any insight as to how they attach to the body and whether or not this is feasible?
edit typo
edit typo
I'm assuming you're talking about the panels that are color-coded to match the flares?
From the factory I think they attach with clips into the sheet metal panels.
You might could use some 3M body panel adhesive but that may be more than you're wanting to do.
Fink
Fink
Yes those panels. I wouldnt mind using an adhesive as long as it would be strong enough to hold up to some wear and tear.
This is what you need.
When you do it, prep, prep and prep some more...then read and make sure you prepped it right.
Stuff like that are all about prep and environment when you're doing it.
Good luck!
Fink
Good luck!
Fink
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
rushw
07-18-2015 01:46 PM
