Lowering the Center of Gravity
"Lower" the stock springs? As in CUTTING them? Don't EVER cut a set of springs.
If you want to lower your truck, thus lowering the center of gravity, then move to a shorter set of springs. The ride will stiffen up, you'll reduce your ground clearance, and the whole "off road" concept will become more of a pipedream - if that was a concern to begin with.
Originally Posted by andrewmitch
Is it possible to just lower the stock springs in order to achieve this?
intial response:
wrong forum.
clever reponse:
it's not possible. stop trying.
newbie bashing reponse:
search you damn newbie, this has been covered, even on this board.
So I do require actually switching the springs. I thought maybe they could be moved.
I never do the type of off-roading like most folks here do (just use it down dirt roads with some small rocks). It is really an on road vehicle and for winter driving.
Your vehicle is pretty stable to begin with... When you start lowering it, you're gonna trash it's performance in the snow. (I assume that your reference to "winter driving" is in the scope of being in Connecticut).
In fact, I would look into lifting it in order to fit larger tires (better bite in the snow) and better ground clearance (to deal with the ruts).
I don't think lowering it one inch would run its winter weather capabilities but I will certainly take that into account before doing anything. Maybe Bilsteins and Addco's is all I need for better on road cornering????
if you don't have sway bars on both front and rear, having both will increase you're cornering abilities more than shocks per se.....A stiffer shock will make the ride rougher, but I suppose it would help cornering a little. I question the importance of cornering in a truck or SUV tho....sounds like an oxymoron.
if you want an SUV with cornering ability, go with a Cayenne. I about passed out when I went out to Barber Motorsports Park and the local instructors were drifting them around corners, burning off rubber the whole way. Really was amazing. Due to the construction of an SUV, they will (as built by toyota and most manufacturers) NOT handle as well as a car or even a station wagon. A Volvo with awd might suit your needs better, if you want performance, a small ammount of offroad capability, and cargo area.
Want a lower CG?
What is wrong with cutting springs? Zeech. big deal. Don't use a torch, keep things cool while you cut 'em and there ya go. What you need to know that as you cut off a coil spring the spring rate goes UP because the spring is shorter. Nothing fancier than that. The next big problem is that you won't have that nice flat bottom on the spring anymore so it tends to fall off or not seat right on an upper mount.
get a set of extra springs and chop a loop off those so you can later go back an put the factory coild back on because the shorties ride too hard, bottom out too often and the rocks keep stopping you on the trail.
I'm not sure why you would want your truck lower, but hey it is your truck I say go for it.
Originally Posted by calrockx
intial response:
wrong forum.
clever reponse:
wrong forum.
clever reponse:
you'll have to 'cuse chuck. he didn't have his ritalin and wheaties this morning no harm intended
anyways, yeah, as i'm sure you've read by now, this forum is geared towards off-roading mods. however, if you do want to lower your 4runner and you have a 3rd gen, performanceproducts.com sells 1" lowering springs.
but given that you said you'd want to take it on dirt roads, don't lower it. a good set of shocks and new springs will do you a lot better than lowering it. go into our 'off road tech' section and read the "Lift FAQ' to get some ideas and come back with your questions and we'll help you out. but definitely read up b/c there is a ton of info out on lifts.
if you want better cornering, addco anti-sway bars are the ticket. but if you replace your shocks and springs, most if not all of them, will give a much better and slightly firmer ride than stock, thereby negating any need for the addcos...that is, unless you are some crazy guy that likes to take freeway offramps at 80mph. and in that case, sell the 4runner and buy a STi!
bob
yeah, i was just being a little stinker.
bob wrote the elegent response that i neglected from my first post.
only thing i can think of is that if you have a, say, 99,00 3rd gen, get the springs from an 01 or 02 4runner, cause they give a lower stance.
You could also just get lower profile higher performance (traction) street tires on larger diameter wheels, maybe at a resulting -1 sizing, to lower the 4R during the summer, and keep your stock tires for driving in the winter.
