Low Beams out
Old 09-25-2007, 03:48 AM
Nimrod's Avatar
Low Beams out
Well, when you have a truck that just turned 300,000 yesterday, you can expect some quirky problems right? Thats what I am finding. My low beams stopped working. I did the obvious and changed the headlights. It didn't work. Here is the odd thing. With my headlights on and on high beam everything is fine. When I switch to low beam the lights go out but the indicator on the dash remains blue, indicating that the high beam is on.
Switch? That is my thinking now too, but how do I get the switch out? Do I need to pull the steering wheel? How? I tried to take the plastic cover off, but stopped thinking i would break it.
It is a 97 tacoma ext. cab 4x4 with V6 manual trans.
Old 09-25-2007, 05:04 AM
Beartracker's Avatar
You have a short somewhere is my guess. Trace the low beam wires and I'll bet you find something. They may also be dry rotted and cracked. Run a test to see if the wire is broke somewhere. For both low beams to go out at the same time I would not believe it's the lights. Mike
Old 09-25-2007, 05:24 AM
Nimrod's Avatar
I guess I should have mentioned that it started about a month ago while going from high beam to low beam sometimes they would go out, but flipping the high beam flash to pass would bring them back on. Thats why I am leaning towards the switch. That and the fact that the high beam blue light stays on when in low beam. What I am afraid of is the high beams going out next.
Old 09-25-2007, 07:31 AM
Yep, I agree. It does sound like it may be the switch. You can test it or just replace it.I don't have a clue as to the cost, sorry. Mike
Old 09-25-2007, 11:30 AM
eric-the-red's Avatar
This might help
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old 09-25-2007, 04:54 PM
Nimrod's Avatar
Originally Posted by eric-the-red
Wow. Is this for a 97 generation Tacoma? That airbag cap pops right off?
This sounds like my problem to a T!
Old 09-25-2007, 05:15 PM
No, it's for an older 4Runner, but the switch might be similar.
Old 09-26-2007, 04:08 PM
Nimrod's Avatar
Update! I pulled the steering wheel, took the switch assembly apart, cleaned all the grease and crap off the connectors, put it together and it worked! Thanks for all the help, you saved me a few hundred I am sure.
Oh yea, watch out for that little ball bearing on the end of the light switch lever. It could be easily lost.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
bhaithc
09-17-2015 07:53 PM
chuckd83
09-14-2015 03:20 PM
dropzone
09-13-2015 11:18 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Low Beams out
