Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Low Beam Headlight problem. Pic included.
__________________
__________________________ Obstacles are what you see when you take your eyes off your goal. Last edited by Lethal; 06-09-2003 at 10:44 AM. |
#2 (permalink) |
Personal
Sales Rating: (0)
problems.
a guess to your problem would be a bad ground at your headlights and at the right side turner signal. Just a guess .
__________________
Larry 86 4runner given to me by a member of this board. it was a stolen recovery. It's done! 85 shortbed frame chevy springs in rear , 44044's up front, 15" travel shocks, custom rear shock mounts, ford mounts up front ,3"body lift, 3"drivetrain lift. 36" tsl sx welded in the rear and easy locker up front cutsom bumpers and sliders |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
nope grounds are good. checked them and all fuses, no knicks or kinks in the lines. everything seems tight and basically correct. can't figure it out and I WILL NOT take it to the stealership unless I know the problem because they misdiagnose the problem so many times and their $98 per hour rate is too much for how little they know.
Any other suggestions please? Having a night time curfew kinda sucks.
__________________
__________________________ Obstacles are what you see when you take your eyes off your goal. |
#4 (permalink) |
Personal
Sales Rating: (0)
Lethal, awesome looking rig. I'm no electrical guru, but the one thing you mentioned that sounds fishy is the steering wheel motion adding to the problem. Since the switch controlling everything you describe as faulty runs through the steering column, could a wire be making an intermittent ground or short inside the light switch or harness that runs through the column? Diagnosing electrics can be tough (and expensive if a dealer does it), but try removing what covers you can for a good visual inspection and cleaning of connections inside the steering wheel housing area. CAREFUL WITH THE AIRBAG CONNECTORS! Good luck, at least we have daylight until 9 PM!
__________________
'07 FJ Cruiser TRD SE 6M/T |
| Tags |
| 4runner, 600, beam, beams, drl, e36, fix, fzr, headlight, headlights, infiniti, low, lowbeam, work, working |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| HID???? Need help with finding a dual hi/lo beam HID headlight system, is it worth it | tx4runnerTRD | General Electrical & Lighting Related Topics | 28 | 12-27-2007 04:26 PM |
| High beam headlight doesn't work | dynamic73 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-06-2005 01:50 PM |
| drivers side low beam was out, not bulb | mainer | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-19-2004 02:15 PM |
| Real HID High & Low beam H4 kit for sale... | pfdaxe | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-30-2002 04:51 AM |
