Loud fan noise from engine
Old 03-22-2008, 09:17 AM
fasthorse67's Avatar
My engine makes a loud fan noise, that gets really loud when the RPM's increase. How do I know if the fan clutch is good? Should the fan rotate freely when the engine is off? or is this a normal noise for 3.4 4Runners?
Old 03-22-2008, 09:20 AM
Adam F's Avatar
Totally normal on a cold start. The fan clutch uses a silicone fluid. When you first start it up its settled and engages the fan. After about 5-10 seconds the fan should quiet down. It will also get loud when the temperature is high outside.
With a cold motor you should feel a lot of resistance on the fan. With a normal operating temperature motor there should be less resistance.
Old 03-22-2008, 09:29 AM
It does it all the time. With a warm but not hot engine should the fan continue to spin a small amount if you try to quickly spin it by hand?
Old 03-22-2008, 10:22 AM
PunaTaco97's Avatar
Fan Clutch
My toy was doing the same thing and it was the fan clutch. Fairly simple to replace.
coryc85
09-09-2015 06:24 AM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: Loud fan noise from engine
