loud creaking noises when turning.
Old 10-11-2004, 04:53 AM
ken.vs.ryu's Avatar
Question loud creaking noises when turning.
steering wheel on full lock, truck stationary, give her gas and loud creaking noises eminate from the front. usually happens when getting out of parking spaces. what should i check?
Old 10-11-2004, 05:13 AM
ranma21's Avatar
Looks like your cv joint is going out. Try visually check and see if the cv boot is torned. Normally you will see lot os grease around it is it is torned. Sometimes the cv joint can go bad even the boot is still in good condition. Hope this help
Old 10-11-2004, 06:11 AM
leebee's Avatar
you may be experiencing the creaking/groaning sound from the steering stops. there are bolts on either side that have a plastic cap on them that eventually wear away, when they do, the bolt face rubs on the stop causing the creaking sound. take a look behind the front wheels and you should see the bolts, the face should have a bit of wear on it and maybe even the remnants of the placstic caps. grease them up on a regular basis and that should cut down the noise.
lee
Old 10-11-2004, 06:16 AM
gwhayduke's Avatar
Listen to Lee.
Old 10-11-2004, 06:18 AM
NCSU's Avatar
Yep, its what Lee said... thats what I always do, just throw some grease on them and you'll be good to go.
AW1090's Avatar
I'm with lee on the stops!
Old 10-11-2004, 12:44 PM
bike4miles's Avatar
Lee is right. The key is "full crank". Just dab some grease on them and they will be good for about 3-6 months depending on season.
Old 10-11-2004, 04:00 PM
93bluetoyota's Avatar
I had the same problem. So my mechanic replaced them since he noticed they had completely worn through the plastic stoppers.
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: loud creaking noises when turning.
