Loss of power
Old 07-12-2004, 07:08 PM
Praufet's Avatar
Loss of power
So I've had my new junkyard engine in for a couple of weeks and now all of the sudden I have no power. I have to be a full throttle to maintain 70 in 5th on the highway (@3000rpm). What should I check? It idles fine just no power.
Old 07-12-2004, 07:15 PM
ChickenLover's Avatar
Is there any choking or studdering?
Old 07-12-2004, 07:38 PM
gwhayduke's Avatar
Did you replace the timing belt?
Old 07-13-2004, 05:33 AM
Praufet's Avatar
Yes I replaced the timing belt. Or rather my mechanic did, and we reset the timing to the specs given.
No stuttering its just no pull when I press down on the throttle. From idle it takes forever to get up to any speed at all.
Old 07-13-2004, 06:34 AM
Praufet's Avatar
Actually after driving to work there is some stuttering if I let of the throttle just right
Old 07-13-2004, 03:13 PM
Praufet's Avatar
After driving home from work I noticed a lot more stuttering, guess its just one of those things it takes some to mention to notice.
Old 07-13-2004, 03:19 PM
Check plug wires, clean air filter. Could be bad gas too (though that's unlikely).
Old 07-13-2004, 04:12 PM
Praufet's Avatar
plug wires are good, air filter is only 2,000 miles old. All was fine up until about a week ago.
Old 07-13-2004, 04:15 PM
Should have clarified, I mean make sure the plug wires are securely connected at both ends. A loose wire will cause power loss and rough running.
Also make sure you don't have a loose vacuum line in there somewhere, that'd do it.
Old 07-14-2004, 06:38 AM
Praufet's Avatar
So check plug wires and hoses all are good. Just to test something on teh freeway to work today I put it into cruise and it wouldn't hold speed. It just slowly dropped, any idea what this means? Bad tps? Something else?
Old 07-14-2004, 06:44 AM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Sounds like bad vacuum, that's what holds the cruise control on speed.
Old 07-14-2004, 06:50 AM
Praufet's Avatar
I figured it be something else since I'm having problems accelerating to begin with. Figured what ever is keeping me slow is hurting the cruise control, but I'll check that out.
Sleaker
08-26-2020 06:03 AM
tj884Rdlx
08-28-2015 12:04 PM
Tacoma1313
08-17-2015 05:44 PM
nate2919
08-06-2015 04:00 AM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Loss of power
