losing power
losing power
i have a 96 sr5 runner with 121k miles and it seems that it just doesnt seem to have the power it used to have. i have done numerous services and it just doenst seem to get any better, as well as the gas mileage. i have done spark plugs, timing belt and water pump, tranny and diff fluids, oil and filter, front brakes, Air filter, cleaned throttle body, attemted to clean MAF but mine is the wierd jet looking one. all this has been done in the past 2-5k miles. the only other things i can think of could be my exhaust such as a new cat and or o2 sensor, or somebody had told me that the rear brakes can be hung up and dragging (i dont think its this though), or possibly a injector cleaning with some sea foam(which im afraid to use, dont want to foul my brand new plugs).
From what you are saying i would have to go with the cat--been there before--slow death with possible overheating. Good luck.
Oh Yeah--i think i have the same MAF as you--used a can of Electronics cleaner with the little red plastic hose attached, bright light and attempted to clean what looked like the hot wire. Dont know whether it helped or not but if you take your MAF off and shine a light on the nose of the jet looking part you can see a wire down there. I am not sure whether that is the hot wire or not--but i cleaned mine and there havent been any ill effects. Anyways good luck.
well lets hope that it is the o2 sensor becauase i just ordered one, it should be here on fri or sat. but in the mean time i will get that cat looked at.
delmert
09-30-2015 04:34 PM
Luvmeye22re
08-04-2015 03:53 PM
