Look what i installed this weekend :)
Old 11-11-2007, 07:51 AM
crolison's Avatar
Got a used arb locker from a friend, set it up and installed it this weekend. It took a while, but this thing is great
What ya guys think?
Compressor Installed
Shafts Pulled
35"s look nice
heres the baby
Switches
Old 11-11-2007, 07:58 AM
camo31_10.50's Avatar
looks great...hope you enjoy it....i sure do wish i could get a good deal on a locker...or better yet 2 of them..lol..sure would be nice to lock it front and rear...show off to my friends alot..LOL
Old 11-11-2007, 09:54 AM
unitofstuff's Avatar
Originally Posted by crolison
Switches
Best interior mod ever.
Old 11-11-2007, 10:00 AM
Skrillah's Avatar
Very nice! How bad was the install?
Based on the pics of that rear end...I'd say a suspension upgrade is greatly needed! Then you can really put that ARB to work!
Old 11-11-2007, 10:32 AM
881stGenRunner's Avatar
looks awesome man, wheel the piss out of it
Old 11-11-2007, 10:43 AM
crolison's Avatar
Originally Posted by 881stGenRunner
idk if its jsut me, but pics arent showing up. did you move them to another folder on your photobucket?
Should show up, didn't change the folder, links or anything.
The install wasn't that bad, just pulled the third out on friday (45 minutes) and took it down to hudlows axle to get set up. On Friday wired up the compressor and ran the air hose, and changed my oil. Saturday ran down picked up the third, cleaned up some stuff, and put her in. The hardest part was connecting the air hose to the diff, we had to run to ace to get the right parts then they were really tight and took some work to get them on.
Then on the lift it wouldn't lock up, and we were so pissed. But we took her down and i reversed out and tried it and it locks all the time now.
Suspension is next on the list of major mods. Going with Toytec adjustable up front, and some OME springs and some bilstein 5125 or 5150 shocks, and some tweaking.
Old 11-11-2007, 10:47 AM
soudns like you got a good set up coming along here.
im going to say that its just my cpu.
Old 11-11-2007, 11:44 AM
Godzilla's Avatar
Lockers are nice indeed. love my factory one. i hope all that excess line off the compressor is before routing it.
Old 11-11-2007, 12:06 PM
crolison's Avatar
Yep it is, and we covered the air line with fuel line hose for added protection.
Old 11-11-2007, 01:13 PM
BajaRunner's Avatar
I dont know what it is, but, I have a big bundle of electronics and what look like brake lines going to where you mounted that compressor. I just bought an MV-1050 and would like to mount it in the engine bay, but, there is no room that I can see.
Old 11-11-2007, 01:38 PM
crolison's Avatar
Yep thats the abs system. Which mine didn't come with.
Old 11-11-2007, 02:38 PM
BajaRunner's Avatar
You're lucky! I'm going to have to do some major re-arranging in there to fit a compressor. Looks like i'll have to take off the damn fender to get a nut on my bolts... Grr..
Old 11-11-2007, 03:33 PM
Fo_SheeZy's Avatar
Man those switches inside look cool!
Old 11-11-2007, 03:42 PM
crolison's Avatar
I also have the mv1050, or equivalent. Someday I will mount it in the cargo area, but just portable for now. The fender isn't hard to undo, you can switch the bolts around and it should be alot easier, you can just stick your hand up the fender to get to it, or at least unbolt a couple of the bolts and tilt it to get to the bolt. We had to half way unbolt the fender to get the snorkel on.
Old 11-11-2007, 03:51 PM
fork's Avatar
ARB :drool:
Old 11-11-2007, 04:40 PM
YodaPala's Avatar
What ya guys think?
Shafts Pulled
35"s look nice
heres the baby
Switches
Pure Sex
Old 11-11-2007, 04:51 PM
aviator's Avatar
So just curious is the ARB compressor belt driven or electrical? does it come with /need a tank? looks like a really clean install...
Old 11-11-2007, 05:04 PM
crolison's Avatar
The arb compressor is electrical, and it has its own little air tank. The mini compressor, which is what i am using is pretty much only good for lockers. I highly suggest using one of the arb compressors for powering an arb locker. The wiring harness that comes with it is excellent, it comes with everything (wiring) to run front and rear lockers.
Old 11-11-2007, 05:17 PM
rocket's Avatar
I wish i didn't have ABS crap taking up all that space. Thats a perfect spot for the compressor. Nice install.
nvdesertrunner
05-11-2020 08:18 PM
ripp96
07-31-2015 11:14 AM
Esibnitsud
07-30-2015 08:19 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Look what i installed this weekend :)
