Lockers: What Years?
Old 08-03-2004, 10:03 PM
AKennedy87's Avatar
What year Tacoma and 4Runners (Limited/SR5) came with rear lockers from factory?
Old 08-04-2004, 04:31 AM
bamachem's Avatar
4Runners started in 96 and was available through 2000. In 2001 they dropped it for the traction control system. I have no clue on Tacomas, but all TRD package Tacos have them including the Prerunners.
Your runner has a 8" rear. That matches other 4Runners and maybe Taco Prerunners. It does NOT match the TRD Taco 4WD since they have a 8.4" rear.
Old 08-04-2004, 05:32 AM
Quote "Your runner has a 8" rear. That matches other 4Runners and maybe Taco Prerunners. It does NOT match the TRD Taco 4WD since they have a 8.4" rear."
Actually it does. The TRD Taco with the locker is an 8" rear end. Also, the locker could be optioned in the Taco without the TRD package. Any Taco with the locker has the 8" rear end. The Taco's that don't have the locker are 8.4" rear ends. The locker can not be put in a 8.4" rear end.
Another way of distinguishing a 8" from a 8.4" is the oil drain plug. On the 8" rear end, the oil drain plug is on the drivers side of the vehicle. On the 8.4" rear end, the oil drain plug is on the passenger side of the vehicle.
Hope this helps.
Old 08-04-2004, 05:38 AM
bamachem's Avatar
Ahhhh... :pat:
Old 08-04-2004, 06:18 PM
AKennedy87's Avatar
Hmm ya know how they make different gears for 4cyl and V6. Well can you use the V6 gears and 3rd member with a 4Cyl engine providing everything is set up right? (Will the gears work okay?)
Old 08-04-2004, 06:36 PM
snwbdr's Avatar
tacos started coming with lockers from the factory starting in 98
Old 08-04-2004, 06:40 PM
kyle_22r's Avatar
of course, the V6 carrier, third member and (usually) gearsets are stronger than the 4 cylinder ones though. pretty common upgrade
Old 08-05-2004, 08:18 AM
payyourtoll's Avatar
My truck has a button for rr locking diff, is this a separate option from center locking diff, or is this the only locker offered in 96?
Old 08-05-2004, 01:34 PM
kyle_22r's Avatar
if it says "RR DIFF LOCK" that's for the TRD rear locker
Old 08-05-2004, 03:28 PM
914runner's Avatar
Is this in your '91?
Old 08-05-2004, 05:16 PM
no, my 96
I have two
Old 08-05-2004, 05:29 PM
4-RUNNIN' FREAK's Avatar
I have a center diff locker from the factory in my '02. Is it the same thing?
Old 08-05-2004, 08:04 PM
AKennedy87's Avatar
What is a center locking diff? I saw it on the sequoa too and was curious to what it was.
Also, is the VSC and traction control, and also the Downhill stability control better than just a locker? Petersons 4wd seemed to really like it in the 4Runner and Lexus 470(winner of Truck of the year) but they liked the Lexus because of the shiftstyle of transfer case (stick instead of button).
Old 08-05-2004, 08:23 PM
calrockx's Avatar
a center diff lock sends equal power to the front and rear driveshafts. when it's unlocked, it's like All Wheel Drive (safe to use on pavement), when it's locked it's like true 4 wheel drive.
it's nice, but no substitute for a rear locker. same with vsc.
Old 08-06-2004, 12:11 AM
Darx's Avatar
My 98 3.4L had a rear locker and it wasn't a TRD model. It also had manual hubs from the factory. I really miss that truck.
Old 08-06-2004, 09:16 AM
roger's Avatar
Given this fact, can the whole 8" rear end with locker be swapped into a Taco that doesn't have the factory locker? Reason I ask, that's a mod I would consider in the future, if I could do it.
Old 08-06-2004, 09:31 AM
kyle_22r's Avatar
i bet you could, since the axles are probably going to be the same width. good idea if you can find one cheap enough
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
Road Bull
10-10-2015 04:55 PM
irritech
07-27-2015 05:15 PM
daddio
07-18-2015 10:20 AM
Quick Reply: Lockers: What Years?
