Lockers: Model and Description
Another locker question. I've been curious about this for a while. What lockers are manual and full time or 4wd electronic engage. Could one describe all the differences.
ARB is a compresser that turns it on with a switch.
Toyota Electronic is engaged when 4wd is engaged.
Lock Right is full time and replaces some gears, and clicks a lot.
What other good tipes are there, especially a Detroit Locker. Are they full time or what?
If someone could explain this to me it would be greatly appreciated.
Thanks a lot,
Alex
Thanks a lot,
Alex
it comes down to this: open differential, limited slip differential, selectively locked differential, and automatically locked differential
open: one wheels spins although supposedly both do but it never happens that way (best on a daily driver with no plans of wheeling outside of graded gravel roads)
limited slip: both spin to a point, then one will brake free (best for mainly a street driver with mild offroading in mind)
locker [automatic or selective]: locks both wheels together for ultimate traction
A little bit of rehash, a little bit of clarification (hopefully):
Open - contains spider and side gears that allow full differentiation. They allow the wheels to rotate at different speeds around corners or when one tire has no traction. Average speed of both tires remains constant ie one will speed up around a corner, one will slow down. Power is typically transmitted to the tire moving fastest. Unfortunately, when one tire has no traction, it is getting all the speed and thus power.
I welcome any corrections/additions.
- Almost all stock differentials are open
- Detroit Tru-Track (gear driven)
- TRD (clutch packs)
- Auburn Gear (clutch packs)
- Detroit EZ-Locker (drop-in)
- Lock-Rite (drop-in)
- Aussie Locker (drop-in)
- Detroit (full carrier)
- There is a Toyota 8" spool available but I'm unsure of the manufacturer.
- Welded or "Lincoln-Locker"
- ARB (air operated, open)
- Factory Toyota electric (electric but can be cable operated as well, open)
- Factory Toyota cable (cable operated, found on some Landcruisers before the electric model came out)
- OX (cable operated, no longer available, no Toyota applications)
- Detroit Elec-Trak (electric, limited-slip, no Toyota applications yet)
Thanks for all the advise, some of this wasnt clear to me.
I dont think I have cash for a all out locker yet but wanted a lil better traction. I have heard the Automatics were pretty danderous especially since we get a good amount of snow up here in MA so I want to stay clear of those.
I was thinking about a limited slip and saw the Detroit Tru-Trac but saw this
"DETROIT TRUETRAC TOYOTA 8 IN 4 CYL REAR ONLY 30 SPL ALL"
What does the ONLY 30 SPL ALL" mean, 30 spline?
It may be good to get something like this but I have a feeling I'll just save up my cash and get an ARB someday...
Again thanks for all the advise,
Alex
Alex
Alex
Alex
Go prowl around the Reider Racing site. Lots of great descriptions of various products. It isn't complete, they only describe what they sell, but there's plenty there to learn about. www.reiderracing.com
kawazx636
10-06-2021 03:03 PM
Odin
09-26-2015 06:56 PM
