Locker Advice
Locker Advice
Have an 89 runner on 35s. strictly mud/sand use. any suggestions on a rear locker. realiability, affordability, easy install. thanks
look into the aussie locker... for all out strength a detroit locker will outlast any other axle part, but the lunchbox lockers are an easy drop in install.... the detroit is a full carrier replacemetn and requires the gears be re-set up.....
if its jsut an offroad rig, you might want too look into a min or full spool (but again will need gears setup) or a lunchbox locker liek the aussie locker or similar for the easiest installs
It locks the axles togther alowing nothing to turn at different speeds. It is also the cheapest because it is a simple hunk of metal.(no turning parts)
I would be cautious with mini spools. From what I have heard they are very weak and break easily. There are 2 kinds of people with mini-spools, those who have broken them, and those who will. Do a search on pirate4x4 about them, youll see.
1uzRunner
63
11-10-2018 03:58 PM
zz_denis
09-06-2015 03:43 PM
justdifferentials
09-05-2015 06:52 PM
