locating current opening efi relay
Old 02-17-2005, 07:53 PM
brad nippa's Avatar
I have a 1986 4 runner. The fuel pump is new and works fine. Once installed, I tested it with a jumper wire, direct from the battery. The car starts just fine. However, it won"do so on it's own, there is no power to the pump. I checked with the parts department, at three different dealers, and they all say that the likely cause is a defective current opening efi relay. Now they all say It's located under the dash on the passenger side. I pulled the kick pannel, and the glove box. There is a relay left of the glove box opening, but the numbers don"t match. The part No. on the side of the correct relay is supposed to 8591014020. I need to find the correct relay to replace it. Plus they indicate there's now way to test the relay, Is that true? Any help would be appreciated. Thanks.
Old 02-18-2005, 08:42 PM
4Crawler's Avatar
Circuit Opening Relay location
You'll probably find most of that information on my web page (and it is the Circuit Opening Relay):
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Hint: Look behind the ECU
Old 02-18-2005, 08:46 PM
NCSU-4runner's Avatar
i believe its called the circuit opening relay, could also check the fuse box in the engine bay, theres a couple relays there.
Old 02-20-2005, 10:23 AM
slojo's Avatar
circ open relay location
the circ opening relay is up in there on the side wall behind your speaker. U probably checked fuses and Main EFI relay already but i thought i would mention it also. Ive just been all through that on my '85. good luck
jaretstuff
08-04-2015 02:08 PM
toofly1999
07-25-2015 07:09 PM
jackiebrownia
07-20-2015 09:02 AM
Sandman
07-14-2015 12:36 PM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: locating current opening efi relay
