Limiting Moonroof travel.. How?
Old 07-13-2010, 11:44 AM
nah2323's Avatar
Hey everyone,
Quick question, is there a way to limit the travel of the moonroof? I'm adding a window module to my alarm system, and when I lock it, it rolls all of the windows up... But.. The sunroof goes past closed, and to full tilt.. I don't really need the tilt function, so i'd like to disable the tilt somehow. Can I do it with the limit switches, or something along those lines?
TIA
Nah2323
Old 07-13-2010, 12:08 PM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
might be able to cut a wire in the harness... when i retrofitted the controls in the overhead console, i believe there were 1 or 2 wires specifically related to the tilt function. certainly want to peruse a Mitchells wiring diagram first if you go that route, though.
Old 07-13-2010, 12:38 PM
nah2323's Avatar
I have the Toyota FSM, but it's not informative enough.. It tell you how to check function. I'll go over it one more time to see.
Anyone else?
Old 07-13-2010, 03:10 PM
nah2323's Avatar
I just drew this up from the FSM, but not sure where to interrupt this thing to stop before the tilt. My window module says I need to connect to the wiring between the motor and the switch.
primordialbeast117
12-19-2015 12:23 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
charlie_fong
09-27-2015 10:06 PM
BimmerSage
09-17-2015 11:48 PM
Quick Reply: Limiting Moonroof travel.. How?
