LIft Sagging, HELP
LIft Sagging, HELP
Hey guys I am afraid that I am sagging a little bit in the rear after lifting my rig 2.5". Iwas told here to get the Downey HD 2.5" coils for the rear of my lift. I did so without thinking one bit about the setteling out issue. For about a week now I have noticed that my baby is starting to look a little low in te rear. I used front spacers, so no sag has occured there, but the rear is definatley hanging a little low. I was just wodering if there is any quick fix for that. Could ya please let me know. ANY suggestions are welcome, big or small, simply or not, I just NEED ideas.
The one thing I was thinking about and wanted to get an opinion on was if a set of air bag AirLift would work. You know the kind of air bags that go into your rear springs to help correct load sagging when towing. Please let me know what you think of that idea.
Here is a link to a system that PP offers, Air Lift System
Senior Member
Have you thought about running a 1" or 2" spacer in the rear. I think http://www.cornfedsuspension.com/ carries them. They are more than the airbag setup though.............
Yeah I hae thought about the spacer option again or the rear but Iwas looking for something a little cheaper if it was possible, but spacers are always the fall back when everything else doesn't work.
Also I am convinced that the spacers that I ued up front are the reason that my ride is rough. I ony feel the bounce from the front.
In your opinion do you think the air bags wil work for me at all?
Thanks in advance.
Thanks in advance.
1uzRunner
63
11-10-2018 03:58 PM
