lift for pickups?
Old 03-21-2003, 06:47 PM
decepticon's Avatar
lift for pickups?
ok i have a 93 pu. I searched for lifts and most of them came came up with 4runners. I heard its pointless to go with an actual lift kit and is rather a waste of money. I know the way to go is sas, but i cannot afford that. I already have a 2' bl on it and want to go so i can fit 33 under there. can somone point me in the right direction on where to look for my next avail options? I heard of daystarr, but also heard they suck. anything else?
Old 03-21-2003, 06:51 PM
Guest
oly884's Avatar
I've got a procomp stage 2 on my 90 pickup. I love it, how much are you going to wheel? I go out every now and then and don't really have any problems. It fit's 33's very nice. If you do plan on going wheeling then get the stage 2 because it makes the front end much more strong.
Old 03-21-2003, 06:56 PM
decepticon's Avatar
i go every now and then, its my daily driver. Im in the process of installing 5.29 gears with lockrite, (paid only 185 for it) performance cam, and a jet ecu upgrade. I currently run 32 and a 2' lift. want to be able to fit 33,
Old 03-21-2003, 07:05 PM
Guest
oly884's Avatar
If that's the case then go with the procomp lift and put on 35's since you're putting in 5.29's.
Old 03-21-2003, 07:16 PM
decepticon's Avatar
can my 4 cyl handle that size? I dont wanna be doing the same speed as the old granny drives cause i cant go faster than them
Old 03-21-2003, 07:28 PM
Guest
oly884's Avatar
If you said that you're getting 5.29's then it'll be no problem.
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: lift for pickups?
