Lift noise, Help!
Lift noise, Help!
So I installed my OME 3" coil lift from toytec. It has a small front spacer as well. I keeped the OEM front struts put Bilstein's in the back. It rides nice but there is a noise coming from the front (seems to driver side) sounds like two washers hitting together whenever i hit a bump. What could this be??
Thanks
Thanks
Check your sway bar and make sure the bolts are tight.
Were you certain that the coil spacer was seated correctly?
Get back undernieth it and look around at all of your connections to make sure nothing came loose. Your rig shouldnt be making those noises.
Throw some pics up too!
you probably didn't tighten the strut nut down far enough so were it would seat on the part of the strut where its flared out so that the washers and bushings between the top out plate, i did the same thing and its pissing me off, every time u hit a bump you hear that washer clanking around.
genuinegemini
08-03-2015 04:56 PM
