Lift Kit Gas Mileage
Old 05-09-2006, 10:32 AM
Sweet99's Avatar
Any thoughts on howm much my gas mileage will change once I install a 2.5" lift kit and 285s on my 99 limited? I am still deciding between the Sonoran Steel set up and the Wheelers Offroad kit consisting mostly of OME components. I currently get about 18 mpg on the highway stock. I'm about to be driving back and forth between Austin and Dallas a lot, so I don't want to lift it if it is going to lower the gas mileage a great deal.
Thanks in advance!
Old 05-09-2006, 10:41 AM
rimpainter.com's Avatar
I lost about 1 mpg when I installed my 1" body lift, front bug deflector, and sunroof wind deflector. Not sure if that helps, but it might give you an idea.
Old 05-09-2006, 10:51 AM
99SR5's Avatar
do those deflectors really effect gas mileage that much
Old 05-09-2006, 10:54 AM
I guess they do. I didn't think they did until a couple guys started mentioning that they saw a difference. I am not sure if it's measurable or what. Anyway, the reason I mentioned it was because I just so happen to do all that stuff at the same time. The 1 mpg reduction could very well be from the BL only.
I guess it makes sense though. More wind resistance...
Old 05-09-2006, 10:55 AM
Localmotion's Avatar
go with sonoransteels setup. He gives you everything you could possibly need to do it right!
As far as gas mileage, maybe 10% decrease at most. I am running 285s with the tundra lift. I also have 211k on my orig. motor.
Old 05-09-2006, 03:52 PM
uberhahn's Avatar
1 mpg per inch of lift. i've got a fabtech lift (roughly 3 inches of lift) on 265 MTs with a manual trans. I drive like a grandma (never over 2k rpm in city, 73 mph max on hwy) and get 21 mpg. should get better after a seafoam treatment and deckplate or airraid mod.
uberhahn
Old 05-09-2006, 05:28 PM
^ it would help to know which engine you have. If it's the 3.4 I find that very hard to believe.
Old 05-09-2006, 05:41 PM
914runner's Avatar
I agree, I hardly get 21mpg on the highway if I stay around 68mph.
Old 05-09-2006, 05:49 PM
Bob_98SR5's Avatar
uberhahn
sweet99,
depends on you gear ratios too. for example, i have 4.10 gr and have 32s. id say i've lost about 1 mpg because of it.
for you, id expect a loss of 2mpg. significant? well that all depends on you and your ability to afford that loss in mpg.
bob
uber,
im having a hard time believing your numbers...unless you got a strong tailwind always behind you how are you calculating this?
Old 05-09-2006, 06:25 PM
KyleT's Avatar
i think tires make a much larger difference than the lift. mine was the same before and after the lift, before the larger tires. and now it is close but not as good, i think part of it has to do wth the recent swich from MTBE reformulated gas to Ethenol reformulaterd gas. so i havent had anough time to get the car used to it ect... MTBE sucks btw, destrys the envoronment. im glad its gone. car runs better too.
Flying91
45
04-11-2024 04:39 PM
smthwsn357
12-04-2023 02:08 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Lift Kit Gas Mileage
