license plate pannel romoval
Old 04-15-2006, 03:03 PM
Patsawasy's Avatar
ive got a 97 limited. My license plate pannel is a little worse for the wear. on the top of it the pain is chipping. plus i recently took of the 4runner badge and i have three holes from the badge as well as "sunburn" form where it formerly was.
my question is, how do i remove this, so i can re-paint it.
anyone?
Old 04-15-2006, 03:10 PM
iceman601's Avatar
You'll have to take off the back/interior cover in order to access the bolts that are holding that in. The back panel cover is held in with a bunch of clips and one bolt I believe. That one bolt is covered with a cap where the strap hangs on the panel. Use a flat head screwdriver and a cloth and slowly pry off the cover off and you should be able to access everything there. Hope it helps...
Old 04-15-2006, 03:16 PM
FUZION's Avatar
Old 04-15-2006, 03:31 PM
Patsawasy's Avatar
THAT explains it. i tried to take off the back pannel a few days back and the pressure locks came out but i did not think to check under the strap.
thanks iceman
kawazx636
10-06-2021 03:03 PM
pickle6415
10-19-2015 08:08 AM
kawazx636
09-29-2015 08:22 AM
Toys4parts
09-26-2015 01:56 PM
AlexJet
09-14-2015 09:00 AM
Quick Reply: license plate pannel romoval
