LED Turn Signal Question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-07-2004, 09:04 PM   #1 (permalink)
ATP4984's Avatar
I was about to place an order on http://autolumination.com/1156_1157.htm for some new 24 LED Brake and Turnsignals for my '93. Then I got to thinking...
If I replace my turn signals with LEDs (which draw relatively little power), will I get the same rapid-blinking effect as with a burned out bulb? Anyone tried this or know of a way to fix it?
ATP4984 is offline
Old 11-07-2004, 09:17 PM   #2 (permalink)
Sludge's Avatar
Send a message via AIM to Sludge
you should be fine since the power draw on the led unit is drawing 12volt. Its the amps that are lower.
__________________
92 4Runner SR5
Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . .
http://community.webshots.com/user/sludg3
Sludge is offline
Old 11-07-2004, 09:19 PM   #3 (permalink)
ATP4984's Avatar
Good thinking.
ATP4984 is offline
Old 11-07-2004, 09:51 PM   #4 (permalink)
Guest
4RUNR's Avatar
Not familiar with those relays, but experience tells me that it is load dependant and you will have to get some dummy load on there if you want the blinking rate to stay the same.
4RUNR is offline
Old 11-07-2004, 10:09 PM   #5 (permalink)
http://autolumination.com/images/leds/installation.jpg
BruceTS is offline
Old 11-07-2004, 10:52 PM   #6 (permalink)
gapguy's Avatar
Send a message via AIM to gapguy
Or just get an electronically controlled flasher..$20.
__________________
2008 Mini Cooper
gapguy is offline
Old 11-09-2004, 04:06 AM   #7 (permalink)
MenaceSQL's Avatar
It's very likely that your blinkers will indicate a blown bulb by flashing quickly since the LEDs will not be drawing enough current. I did this with an EP35 electronic flasher from Autozone and it worked for me. The flasher was a direct fit for my '89 truck. Don't quote me on the "EP35" model number as this is just off from the top of my head but I'm almost pretty sure that this is the correct model number. I can verify it if you want me too.
If you want to go the load resistor route, I do have four of them on me if you're interested. I wouldn't go this route though since it totally defeats the purpose of LEDs. I did try one out with the stock thermal flasher and the load resistor does get really, really hot.
__________________
1989 Toyota 4WD Pickup Ext Cab SR5 Auto
Downey Headers | NWOR/Dynomax Exhaust | No Cat | Bored T-Body | Flex-A-Lite Electric Fan | K&N FIPK | Sylvania Xenarc HID's = Crap | Hella FF200 Fog
MenaceSQL is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
parking light ,turn signal wiring question mean green General Vehicle Related Topics (Non Year Related) 2 07-13-2007 11:53 AM
Introduction & Brake/turn signal question. WYScott General Vehicle Related Topics (Non Year Related) 0 01-21-2007 12:19 PM
LED Parking Light/Turn Signal Mod Complete ATP4984 86-95 Trucks & 4Runners 16 02-11-2006 07:54 PM
Front Turn Signal Power Question LSUMatt1514 95.5-2004 Tacomas & 96-2002 4Runners 3 10-14-2004 11:07 AM
Turn signal/Brake light wiring question pfdaxe 95.5-2004 Tacomas & 96-2002 4Runners 10 07-30-2004 01:05 PM
2009 InternetBrands, Inc.
