LED tail light installation HELP???
Don't know if I am in the right section or not...but if anyone knows anything about installing led's please help!!! I want to use some LED's in place of my normal blinkers. The LED's come with two lead wires coming out of the back of the light. How do I wire that up to my stock set up? Any help...pics...anything would be great! Thanks,
are you talking about regular leds? or do you have some of the automotive type replacemt bulbs? if you are talking about regualr leds you cant run them in an automotive application without didoes, capacitors, resistors, etc kinda thing... they wont interact with the stock electrical system correctly.....
You can Buy LED replacement bulbs at any autoshop store.
I should warn you however they are not very bright during the day.
check this post for a review.
https://www.yotatech.com/forums/f105/clear-tail-light-owners-check-here-bulb-issues-review-62631/
you can checkout www.hidforum.com under LED sections. They have tons of retro info. Just another option for you
Thanks guys! I was talking about new leds. I tried the led bulb replacement for like 1157 applications for instance....you are right 4 Hummer...they suck! Thanks for the links guys...I will go check them out!
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
sabine
07-18-2015 03:59 PM
rushw
07-18-2015 01:46 PM
Johntom240
7
07-13-2015 12:18 AM
