Leaking roof
Old 02-20-2007, 02:34 PM
chadbobb's Avatar
Leaking roof
My 96 4runner is leaking somewhere. It is minor and isn't dropping drops of water yet. But i looked over toward the passenger seat handle above the window, and noticed was darker by the trim and around the handle.
So reached over and felt it and it was wet. Looking harder i noticed that it goes from the windshield all the back to half past the rear passenger window then stops. Then in the far back window in the passenger side there is another ~2 in section that is wet.
Seems really strange to me. I checked all the seals around the doors, but i don't really know what to look for other than a tear, which i don't see any of.
Could this be caused from something else like my sun roof?
Any help would be great
Old 02-20-2007, 02:35 PM
Guest
seanz0rz's Avatar
likely sunroof. make sure the drain tubes are clear. i remember there being a guide on here somewhere. also check the seals around it.
Old 02-20-2007, 03:59 PM
Merlin's Avatar
Not sure if the roof construction is the same on all years, but on our previous '98, the cause of the leak was the rails on the roof where a roof rack would mount.
This may not be the best description, but here goes: if you don't have roof racks (factory), you have two black plastic strips going front - back on top of your roof. Those plastic strips are prone to cracking/fading. They are held on by screws. If the plastic cracks around the screws or the screws rust out, water can seep in through those holes, run down along the side of the headliner, and come out on the lowest point. For us, it was above the passenger side window since we park on a hill facing down. The dealer replaced the black plastic strip that was cracked and the screws that hold it down, and all was well.
Hope this helps,
Merlin
Old 02-20-2007, 04:47 PM
chadbobb's Avatar
I do have a roof rack. I think my roof rails are stock, but the rack isn't. I think the yakima rack is just put into the stock rails. Can't say for sure because it was like that when i bought it. Nonetheless i will take it off and see what it looks like.
I will also check on the drain rails. Do you know where those are seanz0rz
Old 02-20-2007, 06:17 PM
FUZION's Avatar
My 97 leaked too. Never found out where it came from though.
Old 02-20-2007, 06:22 PM
Guest
seanz0rz's Avatar
there should be 4 drain tubes, 2 at the front, 2 at the rear, ill try to find some pics for you.
god the search feature just does not work!!!
http://www1.pacific.edu/~c-eaklan/4r...htwrite-up.htm
Old 02-20-2007, 06:27 PM
Staff
DeathCougar's Avatar
Make sure the tubes are clear!! They tend to clog up pretty easily, especially if you live near dirty/dusty, or near trees.
Old 02-20-2007, 06:49 PM
toyotaoffroad91's Avatar
i have a leak that sounds like yours...it is actually my windshield that is leaking. i pulled the headliner and you can see it comming in....but first blow out the sunroof drains
Old 02-20-2007, 07:51 PM
chadbobb's Avatar
It is hard to tell in the pics. Are those in the roof rack or the sun roof?
The final pics show them on the roof rack, so i think that is them.
Peevedkitten
11
08-31-2015 06:57 PM
Medic22733
08-10-2015 06:49 PM
defrag4
07-31-2015 10:50 AM
HaydenConQueso
07-12-2015 05:22 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Leaking roof
