Largest tires that will fit my stock 82?
Well the easiest way to change the final gearing is....you guessed it...Larger tires!
Yeah Yeah, I know. Poor fuel mileage blah blah blah.
So, what is largest tire I can fit under the 82yota without rubbing the fenders. Keep in mind I really have little articulation in the axle given stock everything.
Ok, thanks.
Ok, thanks.
33s will rub on higher speed turns (when the truck articluates to one side) and if your wheels are turned when you go over a bump (like pulling into your driveway?) if you get 33s take your tires off and trim the inside of the fender a little , just the seem...maybe take a hammer and pound it in a little...but no bigger than 33's and be carefull off-road
Flying91
45
04-11-2024 04:39 PM
djpg2000
11-11-2020 04:56 AM
XtraCab
04-12-2020 05:25 AM
coffey50
07-28-2015 10:55 AM
