KZN185 chassis - YotaTech Forums
Go Back   >
KZN185 chassis
LinkBack Thread Tools Search this Thread
Old 04-19-2004, 01:56 AM   #1
KZN185 chassis
Does anyone know if 4 runners with KZN185 chassis # are technically acceptable for registering in Europe? or how to find out what needs to be modified ?
thanks
Woodpecker is offline   Reply With Quote
Old 04-19-2004, 05:22 AM   #2
KZN185W's Avatar
KZN185 Surf is the japanese-spec 3rd gen 4Runner but with the 1KZ-TE engine(3.0L SOHC turbo diesel, some are intercooled). There are lots of these in the UK, Romania, Russia, and Australia.
HTH.
KZN185W is offline   Reply With Quote
Old 04-20-2004, 12:37 AM   #3
Unhappy
Roy, thanks for your reply .... but .... UK, EU, Japan etc specs are all slightly different and one spec does not meet all regulatory requirements of each market. I am trying to find out which reg's [eg emissions, brakes etc] the vehicle may be outside of for the UK otherwise the cost of modification would not make it worth keeping the vehicle [currently in Bosnia].
Old 04-20-2004, 05:55 AM   #4
KZN185W's Avatar
Quote:
Actually, the ones in the UK are second hand imports from Japan. I just don't know if they made any modifications.
You might like to check out http://www.hiluxsurf.co.uk & http://www.milnerconv.co.uk.
What year model is your truck? There are also prados in there using the same engine (1KZ-TE). Europe already has the low-sulfur diesel so I'm sure emissions won't be a problem with the KZN185 (assuming that the engine is still in good condition). Brakes shouldn't be a problem either. You might like to check into the safety belts, srs air bags. Also, it would help if you can check out the host country's requirements. I believe that those info are available in the internet.
HTH.
Redeth's Overland Trailer Build Redeth005 The Fab Shop 92 07-23-2016 10:56 PM
How to Properly Adjust 1st Gen IFS Torsion Bars to Factory Specs (Via the SM) 89fourrunner 86-95 Trucks & 4Runners 3 02-17-2016 07:52 AM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans TransAmBandit Engines - Transmissions 0 09-20-2015 07:08 PM
I want to swap 3rd gen 4runner transmissions bu need accurate wiring diagrams kelly1450 95.5-2004 Tacomas & 96-2002 4Runners 1 09-02-2015 01:29 PM
Rear Shock Mounts - 89 Pickup Ryall 86-95 Trucks & 4Runners 2 09-02-2015 07:48 AM
Tags
1kztekzn185tdi, 30, au, chasis, engine, engines, hilux, intercooler, kzn185, photo, sale, surf, tdiesel, toyota, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
