YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-27-2004, 01:43 PM   #1 (permalink)
knuckle angle ?
just did a sas and my steering angle is not right but no one knows what it should be set at, i am looking for what degree the steering nuckle should be tward the front or tward the rear just not sure. it is at 0 right now thought that was right but was told that is the prob with the bump steer i have please help
bigamigo is offline
Sponsored Links
To remove this ad, register today!
Old 12-27-2004, 05:16 PM   #2 (permalink)
Bigblock's Avatar
bump steer and sas dont have a whole lot to do with each other
Bigblock is offline
Old 12-27-2004, 05:37 PM   #3 (permalink)
Bigblock's Avatar
might you be refering to Caster?if your camber is off your lowwer frame has spread and i can tell you how to fix that.
Bigblock is offline
Old 12-27-2004, 05:40 PM   #4 (permalink)
Bigblock's Avatar
i thought you had a yota ;anyway alignment basics are all similar
Bigblock is offline
Old 12-27-2004, 06:08 PM   #5 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
the upper bearing of the knuckle should be pointed slightly back, looks like those long shackles that you have on there would tilt the axle in the wrong direction, Toyota's have the shackle in the rear, you could try to shim the axle back down where it needs to be, that should fix your problem
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 4300k Philips bulbs
superjoe83 is offline
Old 12-28-2004, 10:26 AM   #6 (permalink)
that is what i asked as it is now the knuckles are flat so how many degrees tilt should it have
bigamigo is offline
Old 12-28-2004, 11:08 AM   #7 (permalink)
superjoe83's Avatar
Quote:
well, I'm not sure on the exact measurement, but if you didn't modify the spring pads, they should be level to the ground, that will get you close
__________________
- Joe
Old 12-28-2004, 11:24 AM   #8 (permalink)
4Crawler's Avatar
Stock solid axle steering/alignment specs:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Steering
Best option is to get the caster angle checked at a local alignment shop (see if you can get a good deal on a check-only), then get some shims made to correct the angle back into the factory range:
http://www.4Crawler.com/4x4/ForSale/Shims.shtml#FAQ1
I find about 1 degree more caster than the factory setting works well, gives a more stable setup, less prone to death wobble with taller/wider tires.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-28-2004, 04:47 PM   #9 (permalink)
Bigblock's Avatar
if you put caster where it should be,then you screw up pinion angle.i'd set caster to about 4 degrees positive and deal with the occasional failed u joint.
Bigblock is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
TG is out of knuckle studs Stomis Solid Axle Swaps, All Years 5 06-20-2007 01:39 PM
Knuckle implants 4-RUNNIN' FREAK Off Topic Talk 17 05-08-2006 12:53 PM
Anyone ever BEND their Steering Knuckle? amorphous General Vehicle Related Topics (Non Year Related) 5 04-07-2006 02:11 PM
knuckle rebuild kits birfieldbuster Offroad Tech 5 11-22-2005 10:02 AM
need help steering knuckle seal????? chasmc2 95.5-2004 Tacomas & 96-2002 4Runners 7 05-18-2004 12:14 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
