knocking noise coming from front left tire - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-02-2004, 05:46 PM   #1 (permalink)
jayson161's Avatar
Send a message via AIM to jayson161
after i switched to my new tires about a week later i started hearing a knocking noise that is coming from the front left tire. there is nothing for the tire to rub on, ive already checked the bearings and they are fine. i just recently shot grease into the ball joints and i can still hear the noise. it happens at all speads while in 2wd. i havent checked to see if its there with the hubs locked. any ideas or opinions would be greatly appreciative
thanks
jayson
__________________
SFA 1994 toyota pickup 4" front marlin springs/4" rear marlin springs/1.5" rear shackles/5.29 gears/aussie locker/35x12.50 ssr's/15x10 rock crawlers/ARB Bull Bar/Warn M8000 winch/KC slim lites/Bushwacker extenda fender flares/ARB Safari Snorkel---
jayson161 is offline
Old 03-02-2004, 06:16 PM   #2 (permalink)
86toyota's Avatar
Your lugnuts are loose
__________________
Gregg
86 yota extra cab, 4" Pro comp, 33's, cam, header,CF Dual friction, K&N, and so on... (SOLD)
89 toyota 4x4 flatbed
MY TRUCK
86toyota is offline
Old 03-02-2004, 06:18 PM   #3 (permalink)
jayson161's Avatar
Quote:
thats what i thought at first but i just had them retorqued the other day and it still does it
__________________
Old 03-02-2004, 06:37 PM   #4 (permalink)
Roadrunner's Avatar
Do you have this knocking or "clunking" noise going over bumps and pot holes? If so, me too. Still trying to locate the source.
__________________
Ian
2001 4Runner SR5 4x4 - An Evolving Expedition and Search and Rescue Response Vehicle
TJM, XD-9000 Winch, Badland Sliders, SAW/OME Lift, 33" BFG TA KOs, Homemade CO2 Set-up, Optima Blue Top, Cobra 75 WX ST, Icom V8000, Icom IC-F121, 1.0" 4Crawler BL, Hayden Tranny Cooler, Wilderness Rack w/Hella 550s, Snorkeled and Trail Armor by BudBuilt.
TLCA #14,082
SAR Field Team Leader - Shenandoah Mountain Rescue Group
Roadrunner is offline
Old 03-02-2004, 06:39 PM   #5 (permalink)
did you change you rims to or just tires??
lunatic14r is offline
Old 03-03-2004, 04:26 AM   #6 (permalink)
jayson161's Avatar
i changed my rims too. i went from 15x8 aluminum to 15x10 steelies
__________________
Old 03-03-2004, 05:03 AM   #7 (permalink)
86toyota's Avatar
The wider rim might have inside wheel weights that are hitting the tie rod ends.
__________________
Gregg
MY TRUCK
86toyota is offline
Old 03-04-2004, 05:15 AM   #8 (permalink)
Babypig's Avatar
How do the front half shafts look? Check the boots on the cv's, maybe you gotta busted cv.
__________________
Ironpig2 is a 1990 4runner SR5
95 3.0V6, ARB front bumper, Hella H4 conversion, Hayden Trans cooler, Aisin manual hubs, Drilled headlight bezel, Clinometer, Altimiter, Assorted Camera mounts, JVC double din head unit, Hilux Surf emblems, Bridgestone Revo's, OME 901's , N72f's
"Stay calm, Be brave, Wait for the signs."
Babypig is offline
Old 03-04-2004, 05:25 AM   #9 (permalink)
Staff
Yoda's Avatar
Did you get the right lug nuts for the steel wheels? Do the wheels fit onto the front hub correctly? (backspace OK, center hole OK?)
Have the wider wheels made a worn front bearing more noticable?
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 03-04-2004, 09:50 AM   #10 (permalink)
MAIS0N's Avatar
My '98 does this too but I'm all stock in the front end. Mostly noticeable at slow speeds over moderately rough road and tight turns. The CV joints and wheel bearings feel tight, I don't think that's it. If I crawl forward slowly a bit and brake...klunk! Then back up slowly and brake...klunk! It makes me think it's something in the suspension linkages or ball joints. Been doing this for about 2 years now and seems to be more noticeable in the colder weather. I would bet the bigger tires didn't create the problem, just made it more noticeable. Please post when you figure it out. I've been too lazy to tear into it so far and it doesn't seem to get any worse.
__________________
-Pat
_____________________________
1998 Tacoma V6 4WD Limited 5spd
TRD 2nd Gen S/C
RC 310cc Injectors
Denso IK22 Iridium Plugs
Walbro 190lph FP
SMT-6
MAIS0N is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Noise in Front end While Turning Left/ Clicking while going straight. Shirleyda4runner 95.5-2004 Tacomas & 96-2002 4Runners 9 05-20-2007 07:31 PM
Loud Grinding Noise From Front Left 91_yota4x4 86-95 Trucks & 4Runners 9 02-25-2007 10:08 PM
99 alero making wierd noise around left front.... fireteacher Off Topic Talk 9 06-06-2006 07:02 AM
funky noise in front left suspension 89macrunner 95.5-2004 Tacomas & 96-2002 4Runners 5 08-09-2005 11:36 AM
Front left suspension noise Roadtripr 95.5-2004 Tacomas & 96-2002 4Runners 25 08-24-2004 02:50 PM
2009 InternetBrands, Inc.
