Kill switch
Kill switch
Hey guys, i need to put a kill switch on my truck soon, alot of cars at my work have been getting stolen. Should i make the switch kill the fuel pump or power to the whole truck? or is there other methods too?
Location: Far western Kentucky (transplanted from central PA)
You didn't mention what year your rig is, but one sure fire way is to pull the EFI fuse or wire a switch in that circuit. I'm sure there are other ways that won't reset the ECU.
Originally Posted by desert whomper
ok, im a lil confused now, should i kill the fuel pump or the ignition or the EFI, what the hell is the ECU and is it bad to reset. lol im a little new here
I haven't done my runner ,yet.
ok, ...and is it bad to reset. lol im a little new here
Now that I've started overloading you with acronyms, are you sorry you asked?
most people put a switch on the starter, this site: http://www.the12volt.com/relays/page2.asp has a lot of info about starter interupts, if you dont have a car alarm than you will need to do the passive starter interupt.
I'm going to have a "kill switch" installed in my 4runner this week. It's not actually a switch, but to start the car, you have to pull the headlamp-controller back (highbeam position) as you turn the key. Once the car has started, let go of the headlamp-controller (normal position) and off you go. It's a good theft deterrent cuz it's kinda hard to figure it out.
p.s...there are also other options instead of using the highbeam, you can also use things like the cigarette lighter has to be pushed in to start the car.
how did u figure out how to do that our did a shop do it, that soudns pretty cool, i wanna try it.
I took it to a car alarm/security place and they charged me $50 to have that "special kill switch" put on. Since I'm electrically-challenged, I thought it was worth it to have a professional install it.
Originally Posted by 96LTDyota
I know how to steal your car now...
kawazx636
10-06-2021 03:03 PM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
runnermedic
13
09-21-2015 05:20 PM
