Just swapped in elocker into Taco Now have weird issue
Old 06-14-2009, 11:48 AM
BajaKbob's Avatar
I just swapped a elocker rear axle into my 1997 Tacoma using mt Tacoma 5lug axles.I have driven around quite a bit since I swapped it on Friday evening .It drives well but the weird thing is if you give it too much gas it revs up and I get wheel hop realllllll bad .I know its not locked because I have checked that.But It almost annoying.You can drive it like a grandma all over the place and it shifts perfect but the second you try and gun it it revs up and bounces all over .Anyone have a clue as to what this could be.
Old 06-14-2009, 12:45 PM
corax's Avatar
any noises associated with the wheel hop? double check all your u-bolts, drive flange bolts, etc.
Old 06-14-2009, 01:24 PM
BajaKbob's Avatar
The ubolts are very tight and the drive line buts,bolts are tight.Pinion angle is good. No noises but seems like trans is slipping but as soon as I let off the gas then accellerate shifts just fine all the way up to 110mph.
Old 06-14-2009, 01:41 PM
BajaKbob's Avatar
Well after further inspection the pinion is moved slightly more angled upward ,,at least a slight bit more that it was with the other axle.Could that be it
Old 06-14-2009, 01:54 PM
corax's Avatar
how much? when you jump on the gas (heavy load) the pinion angles upward, if it goes too far it could go into u-joint bind.
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Just swapped in elocker into Taco Now have weird issue
