Just recieved my AISIN's
Old 03-13-2003, 03:50 AM
delboy's Avatar
Hi There
Just got delivery of Aisin hubs from local wreckers! Upon first inspection they are a bit rusty inside wita few little dents on the outside! Hoping that the rust is just superficial. Cant wait to get them on and see if they make a difference. Wish me luck!
Delboy
Old 03-13-2003, 04:40 AM
Victor's Avatar
What you see as rust may be some of the same reddish-brown grease I found in mine. The easiest way to clean them if you don't have a gallon of carb-cleaner is in the kitchen with some grease cutting soap like Dawn. I used an old toothbrush and each one came out sparkling in 10 mins. Make sure you dry them real well and it wouldn't hurt to spray a little WD40 inside to get rid of any water left.
I wouldn't worry about the dings on the outside as long as the dial can spin freely to engage and disengage. I used Maguiar's aluminum and mag polish on the chrome base and it came out sparkling and neutralized a lot of the corrosion I had. Use a good grease but don't pack the whole thing with it - just enough where metal contacts metal.
But most importantly congrats. This will be a great mod and only takes about 30 mins to install both sides.
Old 03-13-2003, 05:52 AM
delboy's Avatar
Thanks Victor for your advice! I was just doing some searching for articles on rebiulding AISIN Hubs and foun what i would class as the best instructions ive seen for the procedure. I think they are from a factory manual. If people cant follow this, they shouldn't be doing it themselves! Its a PDF file so it need Adobe Acrobat to read it! Hope this helps people!
Delboy
http://www.yankeetoys.org/doc.htm
Old 03-13-2003, 05:59 AM
metal22lica's Avatar
i should be getting mine today or tomorrow. Delboy..your link is bad. if you could fix it that would be cool cause i would love to read it since i will be doing to mod shortly!! what color will you be painting yours and how much did they cost?
Old 03-13-2003, 06:05 AM
delboy's Avatar
Sorry Metal! Misspelt the last bit, but heres the link to get you right in to the pdf file!
Delboyhttp://www.yankeetoys.org/Documents/AisinHubs.pdf
Old 03-13-2003, 06:16 AM
Thanks Delboy...that is pretty good reading. it says how to in my haynes manual but i like that one a lot better! it gives pictures for every step and we all like pictures!!! Right Corey? (if your reading this)
Old 03-13-2003, 06:54 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Right
Delboy, also look in our Tech section here @ YotaTech.
There are two articles for installing manual hubs.
As for bebuilding them, all that entails is tearing them down, cleaning, then re-greasing.
See my website and look in my mods section to a link on how to do that.
Also here is a link to a 2nd gen factory manul that also has PDF files.
http://www.net-impress.com/4runner/cd/
Old 03-13-2003, 07:03 AM
delboy's Avatar
Thanks Corey
Every little helps! And a picture paints a thousand words! By the way metal22lica, i paid a lot more for them than you did! You got the bargain of the century! Was gonna paint the front black with the handle painted the same colour as my rig. A kind of metallic wine color. What colour you doin?
Delboy
Old 03-13-2003, 07:06 AM
oh yeah...did you post the price on an earlier post? if so i remember. i am going to stay with the classic red and black..or just keep them like they are..or as i like to call it...rustic look...hehe. i will post some pics when i get them and things start to form!! Corey..you crack me up!!!
Old 03-13-2003, 06:12 PM
4x4CPOSEADOG's Avatar
Delboy,
Looks like you are going to have some fun rebuilding and repainting the Aisin hubs. Make sure to take easy on that grease, light coat will do the job.
Check mine out
https://www.yotatech.com/attachment.php?postid=54487
https://www.yotatech.com/attachment.php?postid=54490
Noel
Old 03-13-2003, 11:19 PM
delboy's Avatar
Well, it looks like i was being a bit premature in celebrating yesterday. After spending hte evening stripping down the hubs and cleaning every little bit, i decided to check the inner hub to see if it fit ok on my drive shaft. It was too big. The morons at the wreckers gave me 30 spline hubs instead of 26 spline which i specifically asked for. Im really P***ed off! You wouldnt mind the mistake but, the guy called me after i ordered them to verify the number of splines i needed! Murphys Law! Gimme a baseball bat someone!
Delboy
Old 03-14-2003, 04:44 AM
Staff
Corey's Avatar
Oh crap.
Those are the ones for a solid axle correct?
Hopefully they will make it right.
Old 03-14-2003, 07:33 AM
sorry to hear about the bad news Delboy. you should call them and get it taken care of!! now i am starting to worry about it....
Old 03-14-2003, 09:00 AM
delboy's Avatar
Well i have good news and bad news! The bad news is that i went to the wreckers 1.5 hours drive away and he didnt even know what IFS meant. Apparently, the only toyotas that have IFS around the year of my Surf are Imports and there aint too many of them over here! Will a modern one fit?
The good news is that my 1" Body Lift Kit came while i was out at the wreckers (Thankyou Roger) and it all looks in good order. So will probably install it at the weekend. Paddys weekend! So i will have to leave the pub some time to do it! Thank for your condolences guys. I'll keep loioking for those hubs!
P.S. theyy're really easy to put together after the first one. The second took five minutes!
Delboy
Old 03-14-2003, 07:23 PM
Delboy..dont feel bad..mine still havent arrived. but i got my maglite clips and preformed the maglite mod and it only took like 2 minutes..i will post pics later.
Old 03-14-2003, 07:43 PM
toyota parts dude's Avatar
aisin hubs
delboy you should be able to use any hubs from 86-95 toyota 4x4s. they are all 26 splines. did toyota put solid axles in 86 and newer trucks that they sold in europe? the ones i sold to victor from the yotatech forum were from a 1986 4x4 truck. the 30 spline ones you got over her would fit the 79-85 solid axle trucks. i got some 26 spline hubs i'd sell but the shipping would probably be expensive.
Old 03-15-2003, 06:47 AM
EOD30's Avatar
tpyotapartsdude
I pm'ed you
Old 03-15-2003, 10:26 AM
delboy's Avatar
Jason
The postage would probably only cost about $30, so if they were at the right price i'd have no problem saying 'YES' to those Hubs. Just put in a 1" bosy lift and want to crank the front torsion bars but gonna wait til i have the manual hubs. I'm registered with 'PayPal' or i can arrange payment to suit you!
Cheers
Delboy
Longbed 90
03-11-2019 12:38 PM
kawazx636
09-29-2015 08:22 AM
mxdw88
09-20-2015 03:13 AM
noahstancik
09-10-2015 10:47 AM
Quick Reply: Just recieved my AISIN's
