just ordered toytec lift, is 3" too high???
Old 02-27-2006, 07:23 PM
werdwerd's Avatar
I just ordered a toytec 3" spacer lift for front with diff drop and coil in the rear and a TJM17 front bumper for my 1997 4runner. my ? is, is 3" too much lift in front for the cv's or am I fine with the added weight of the bumper,? also what is the largest tire without rubbing with stick wheels? thanks
Old 02-27-2006, 07:33 PM
BajaRunner's Avatar
You'll probably fine with that setup.
As for the tires you'll probably need a little body lift to clear 285 75 16s or 33 x 11.50
Old 02-27-2006, 08:01 PM
Jonathan's Avatar
285's should fit fine. You may have to shave the upper a-arms if you're using stocks rims; they will rub there if you don't. Lift sounds about right with the heavier bumper, but keep an eye on the CV's to make sure.
Old 02-27-2006, 08:08 PM
sasquatch's Avatar
I just installed the same. Without the TJM bumper. But I got the AAL's for the back. I noticed a slight vibration in the front, and I'm thinking that I need the diff drop to cure it. I haven't got any positive response on that yet, but that's my thoughts.
kazuya2416
04-05-2024 02:17 AM
dumpster84
04-30-2016 06:03 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
TURBOrunnerNM
07-20-2015 08:31 AM
Quick Reply: just ordered toytec lift, is 3" too high???
