Just got 32's trying to fix a few problems...
Well I just got my 32's and have a few problems. All problems are on the front of the truck.
- They rub on the front of the running boards
- They rub on the sway-bar with chains on
To fix the running board problem I was planing on triming them back about 1/2" to 3/4". Then they would clear fine. For the sway-bar problem they clear it fine without the chains on but rub a little with the chains on. All I think I would need is about 3/4" to 1" wheel spacers and it will clear fine.
I found 1" wheel spacers at Marlin Crawler and was wondering if anyone knew of 3/4" wheel spacers?
Thanks
Thanks
Thanks
Thanks
Originally Posted by fiveofeen
those bolt up wheel spacers are exspensive, a different wheel would nearly be the same price, cheaper if you went steel.
Thanks
I am wanting to keep the stock look that my wheels give for now. So I figure wheel spacers are my best bet. I assume that the 1" wheel spacers space each wheel out 1" not each one 1/2" for a total of 1"?
Thanks
Thanks
Originally Posted by superjoe83
you have to consider that when you put the wheel spacers on they will make the wheel stick back farther when turned all the way so you may have to do some more trimming on your running boards
Thanks
Chains on the front wheels. Sounds scary, Iwould be afraid of them getting caught up in suspension/steering components. Not to mention my manual says not to run chains on the front.
I only run chains on the front while im out hunting, which is usually in about a foot or more of snow and I need the front "grab". I used to run chains on the front with the 235's and the chains cleared the suspension fine so I have no worries now that it will hit the suspension with the 32's and now that I trimmed the running boards they shouldnt hit anywhere!
Why didn't you just take the running boards off? It gives a much cleaner and more aggressive look to the rig...probably one of the best and easiest (except for having to cut a bolt off) mods I have done to date.
But I'm glad you got the running board rub fixed.
Fink
Fink
I will most likely replace them with slider eventally but the wife complained that she couldnt get in with the added hight of the 32's, I doubt she would ride in the rig anymore if I took off the running boards! Then Id be forced to drive the mall wagon!
crammit442
7
11-29-2017 12:30 PM
theking11863
03-19-2016 09:36 PM
Peevedkitten
11
08-31-2015 06:57 PM
greyheadedguy
08-18-2015 10:40 AM
