Just a 2" Body lift & 285's? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-08-2004, 10:32 AM   #1 (permalink)
Swede's Avatar
I'm trying to decide between the 265/75's or 285 /75's x 16's (REVO's). I would like to run the 285's if I can.
I have a 2" body lift allready but I don't want to put in a suspension lift yet if I don't have to. My 4Runner has the SR5 trim with running boards, and stock front bumper so there is no added weight up there.
My question is about rubbing. Does anyone have/had this set-up (285's with only a 2" BL) and did they have any clearance problems with it? If you have, could you please distinguish between rubbing offroad and rubbing during normal everyday onroad driving. Thanks!
__________________
'98 4Runner SR5, V-6, 5-speed,
35" Baja Claws,
17x9 Eagle Alloys,
E-Locker,
3" Susp Lift,
3" Body Lift,
Elbow mod,
Deckplate Mod,
"D" gasket mod,
Silverstars,
Headlight Film,
67" TG Sliders,
8500lbs Portable Winch,
Magellan GPS...
Next on the list: 4:88 gears
Swede is offline
Old 09-08-2004, 10:51 AM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Talking 2" RB body lift w/ 285s
I ran 285s with a 2" Roger Brown body lift and had rubbing onroad only when I went over culverts in the road or turned sharply while going up/down and incline and it was minimal. You should be fine as long as you stay on road.
waskillywabbit is offline
Old 09-08-2004, 10:57 AM   #3 (permalink)
Swede's Avatar
Was that with the stock or aftermarket wheels?
__________________
35" Baja Claws,
17x9 Eagle Alloys,
E-Locker,
3" Susp Lift,
3" Body Lift,
Elbow mod,
Deckplate Mod,
"D" gasket mod,
Silverstars,
Headlight Film,
67" TG Sliders,
Magellan GPS...
Swede is offline
Old 09-08-2004, 11:02 AM   #4 (permalink)
Staff
Talking Wheels
Quote:
The ones you see in the pic are 16x8 and stock are 16x7, so these were an inch wider. Mine originally came w/ 15" rims/tires.
Old 09-08-2004, 11:05 AM   #5 (permalink)
keisur's Avatar
I have a '98 and started with a 3" susp. lift and then added 285/75/16's and rubbed a little. I added a 2" BL two weeks ago and I don't rub anymore, but I'm making room for the 305/75/16's which will be next.
my rec, stick with 265's if you're only slapping on the body lift.
A side note, be ready to trim away a little of your shifter plate and clear some of the rubber boot away so you can get it into 2nd and 4th.
__________________
Front: 4.88's w/ ARB Locker
Rear: 4.88's w/ ARB Locker
Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks
Body - 2" HDPE Pucks w/ higher strength bolts
Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch
Lighting: Lightforce Striker 170's
Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT
Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear
Infiniti Kappa Perfect 10.1 Sub
500W RMS amp for fronts and rears; 500W RMS amp for sub
Power: Optima Blue Top
1400 Watt Power Inverter
keisur is offline
Old 09-08-2004, 11:11 AM   #6 (permalink)
keisur's Avatar
also, if you go with the 285's, you'll want to trim the valence where it meets the front wheel well and remove the front mud guards. I removed both the front and the rear because in a good flexxy situation off of the road they would catch the lugs in the tars and I didn't want to rip them off.
If you plan on wheeling, go with 265/75/16's, I ran those with no lift and was really close to rubbing but never actually did.
__________________
keisur is offline
Old 09-08-2004, 12:20 PM   #7 (permalink)
Swede's Avatar
"Waskilly", What I meant was did you rub with the stock wheels or the wider ones, or both?
"Keisur", The lift is allready been done and you're right about the shifter boots, I did trim away some of the boots but I ended up with extra road noise from the modified boots, so what I ended up doing was fabbing up a lower base for the boots to attach to. It's hard to explain what I did and if I had a digital camera I would snap a couple of shots, oh well.
__________________
35" Baja Claws,
17x9 Eagle Alloys,
E-Locker,
3" Susp Lift,
3" Body Lift,
Elbow mod,
Deckplate Mod,
"D" gasket mod,
Silverstars,
Headlight Film,
67" TG Sliders,
Magellan GPS...
Swede is offline
Old 09-08-2004, 12:22 PM   #8 (permalink)
Staff
Talking 285s and stock wheels
The stock wheels were 15" so they never had 285s on them, the aftermarket wheels were 16x8 and they rubbed minimally onroad with the 285s, but definitely driveable everyday.
Old 09-08-2004, 12:39 PM   #9 (permalink)
Swede's Avatar
Perfect, so there could possibly be less rubbing with the 16 x 7 wheels as opposed to the 16 x 8's or minimal difference? I guess it depends on the offset that you had as well too, so, It looks like 285's is the way to go.
__________________
35" Baja Claws,
17x9 Eagle Alloys,
E-Locker,
3" Susp Lift,
3" Body Lift,
Elbow mod,
Deckplate Mod,
"D" gasket mod,
Silverstars,
Headlight Film,
67" TG Sliders,
Magellan GPS...
Swede is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Any pics of 3rd Gen w/ 3" lift + 285's? Geographeen Offroad Tech 21 06-20-2007 04:06 PM
285's with a body lift? HuskyRunner 95.5-2004 Tacomas & 96-2002 4Runners 19 11-30-2006 04:40 AM
Finaly got my lift and 285's. "with pics" RadRunner 95.5-2004 Tacomas & 96-2002 4Runners 29 08-07-2006 08:11 PM
Supercharger & 2" body lift???anyone a9krpm 95.5-2004 Tacomas & 96-2002 4Runners 3 11-20-2004 11:52 AM
2009 InternetBrands, Inc.
